60" mower deck for a 420
4 replies to this topic
#1 blacktruck OFFLINE
blacktruck
  • 32 Thanks
  • 59 posts
Posted July 02, 2015 - 11:11 AM
Does anyone happen to know the part number for the belt for a 60" mower deck? Not the PTO drive belt but the belt running the blade spindles. I took the covers off and the belt is toast (so to speak). Does anyone have experience getting those at the local NAPA or O Reilly's or is this procured through JD only?
As always, I appreciate the help and advice.
Thanks
Ken
#2 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,169 posts
Posted July 02, 2015 - 11:17 AM
Part number is M140021
  • blacktruck said thank you
#3 Bolens 1000 ONLINE
  • 15,427 Thanks
  • 18,282 posts
Posted July 02, 2015 - 11:19 AM
I would get that one from JD
#4 dropped82 ONLINE
dropped82
    Nut Case
  • 2,740 Thanks
  • 1,905 posts
Posted July 02, 2015 - 11:33 AM
I second the JD belt. Deere was good about cutting their own angles in the belts. Others will work but won't last as long. You'll spend the same or more in the end versus JD belts.
Eric
Edited by dropped82, July 02, 2015 - 11:34 AM.
#5 blacktruck OFFLINE
blacktruck
  • 32 Thanks
  • 59 posts
Posted July 02, 2015 - 12:26 PM
Thank you gentlemen.
I will see if the local dealer has one. Much appreciated.
