Fixing this Bolens!
19 replies to this topic
#1 KennyP ONLINE
  • 53163 Thanks
  • 53306 posts
Posted July 01, 2015 - 04:16 PM
My first adventure into Bolens territory. Arron has this Bolens and I told him last year the belts need replaced. Since it won't pull itself anymore, it's time to change them. I have an operators manual . Now to fix it!
Wish me luck!
  • Bolens 1000, MH81, boyscout862 and 1 other said thanks
#2 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted July 01, 2015 - 04:19 PM
Thats not a bolens........................
#3 TomLGT195 OFFLINE
TomLGT195
  • 4155 Thanks
  • 2947 posts
Posted July 01, 2015 - 04:40 PM
looks like an MTD in green paint .  :rolling:
I'm sure when you're done Kenny it 'll be running just fine again .
#4 KennyP ONLINE
  • 53163 Thanks
  • 53306 posts
Posted July 01, 2015 - 04:44 PM
But it says Bolens right on it!
  • boyscout862 and Marty'70 have said thanks
#5 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted July 01, 2015 - 04:47 PM
Its a "Bino"  "Bolens in name only" :poke:
I'm not proud of it But I have sold parts for these machines :D
  • KennyP, boyscout862 and Paulgo have said thanks
#6 KennyP ONLINE
  • 53163 Thanks
  • 53306 posts
Posted July 01, 2015 - 04:51 PM
I just had to stir the pot a little!
  • Bolens 1000 and boyscout862 have said thanks
#7 HANKG OFFLINE
HANKG
  • 6962 Thanks
  • 3671 posts
Posted July 01, 2015 - 05:01 PM
What pricks eh Ken
#8 KennyP ONLINE
  • 53163 Thanks
  • 53306 posts
Posted July 01, 2015 - 05:15 PM
What pricks eh Ken
Seems they all left! Guess I'll have to wing it!
#9 EricFromPa ONLINE
EricFromPa
    Fixer of Broken junk
  • 6875 Thanks
  • 4608 posts
Posted July 01, 2015 - 05:55 PM
LOL
I'll try to help ya a bit.I work on these all the time.
Replace Both belts while you have it apart.That's a single speed rear with Varidrive and 2 drive belts.
To remove the belts it's easier to just remove the big vari drive pulley under the shift plate.They usually only have a Snap ring and a couple washers holding them on.After that you Might have to remove the Engine pulley to clear the engine belt guide.Most of the engine belt guides were Cast into the frame.
Hey they take alot of abuse and still work most of the time.The Varidrive is ALOT better setup than the cheap Peerless gear drives or those darn little weak hydro units.Transaxle is Super simple Forward/Reverse in these and they usually outlast the rest of the tractor.
  • MH81, KennyP and Marty'70 have said thanks
#10 KennyP ONLINE
  • 53163 Thanks
  • 53306 posts
Posted July 01, 2015 - 06:14 PM
LOL
It reminds me of my old MTD a lot. Still have the Vari-Drive pulleys for it!
#11 UncleWillie OFFLINE
  • 16501 Thanks
  • 9061 posts
Posted July 01, 2015 - 07:17 PM
I just bought one of those for 100, put a battery in it and sold it for 200
#12 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted July 01, 2015 - 07:30 PM
In spite of the fact that they are just another MTD clone, they do actually mow pretty well. But that is all they do pretty well.
  • EricFromPa, KennyP and Marty'70 have said thanks
#13 KennyP ONLINE
  • 53163 Thanks
  • 53306 posts
Posted July 01, 2015 - 07:35 PM
I'll have to agree with that statement!
  • Marty'70 said thank you
#14 grattone OFFLINE
grattone
  • 310 Thanks
  • 220 posts
Posted July 01, 2015 - 08:34 PM
If all you need is a lawn machine to mow with, they are not that bad. The drive is not so bad unless you want to shift speeds with out it running, then it gets messed up.
#15 Marty'70 ONLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 1091 Thanks
  • 802 posts
Posted July 01, 2015 - 10:07 PM
I got the exact tractor only called a yard machine... Changed the belts last year WHAT A PITA!!
