buy new or try to fix: 917.251492
14 replies to this topic
#1 Porkchop5 OFFLINE
Porkchop5
  • 1 Thanks
  • 6 posts
Posted July 01, 2015 - 03:45 PM
I have a 1996 sears craftsman 917.251492 whose trans-axel needs repair. Can't find anyone willing to tell me what's wrong with it. Can't find a replacement trans. Anyone have any suggestions. Tractor is in good shape except will not go forward or backwards. What would this be worth if I wanted to sell it. Thanks in advance
#2 olcowhand ONLINE
  • 40,384 Thanks
  • 31,181 posts
Posted July 01, 2015 - 03:56 PM
May simply be a sheared key on transaxle input pulley, or one of the axles/hubs has a sheared key.  Yours may or may not have keyed axles.
  • MH81 and boyscout862 have said thanks
#3 boyscout862 OFFLINE
  • 12,574 Thanks
  • 9,050 posts
Posted July 01, 2015 - 03:59 PM
Welcome to GTT. You aren't giving enough info for a good answer. Is it a lawn tractor or a garden tractor? Can you do the work yourself? If not, it probably isn't worth the cost of the labor. The problem may just be in the linkage but you would need to take pics and post them.
As far as selling it, It may be worth something if the engine runs real good but in general there just aren't that many people working on them. Good Luck, Rick
#4 olcowhand ONLINE
  • 40,384 Thanks
  • 31,181 posts
Looked it up & your hubs do use a key on the axle.  It's likely a key sheared if your belt is turning the pulley being forward & reverse are out.  You can look up the parts & service info HERE.
#5 olcowhand ONLINE
  • 40,384 Thanks
  • 31,181 posts
Posted July 01, 2015 - 04:04 PM
This is a hydro version correct?  Did this happen gradually or all of a sudden?
#6 Porkchop5 OFFLINE
Porkchop5
  • 1 Thanks
  • 6 posts
Posted July 01, 2015 - 04:11 PM
It's a garden tractor. Can't do the work myself. Engine runs well. Just happened all of a sudden.
#7 Porkchop5 OFFLINE
Porkchop5
  • 1 Thanks
  • 6 posts
Posted July 01, 2015 - 04:12 PM
Yes hydro-gear 218-3010L. all of a sudden.
#8 Porkchop5 OFFLINE
Porkchop5
  • 1 Thanks
  • 6 posts
Posted July 01, 2015 - 04:13 PM
Belt is turning. Thanks for the link.
#9 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,016 Thanks
  • 9,645 posts
Posted July 01, 2015 - 04:53 PM
Hmmm. . .      sounds like it could be simple. Do we have any member is this guys area doing repair work?
#10 KennyP ONLINE
  • 37,552 Thanks
  • 45,535 posts
Posted July 01, 2015 - 05:13 PM
Looks to be close to NUTNDUN!
#11 MH81 OFFLINE
Posted July 01, 2015 - 08:03 PM
I can't look at the parts list on my phone, but this thread is something to consider. Sounds like a similar tractor.
http://gardentractor...4885#entry14885
#12 grattone OFFLINE
grattone
  • 309 Thanks
  • 220 posts
Posted July 01, 2015 - 08:22 PM
Have you by chance replaced any belts, my brother in-law replaced his belt and somehow got mixed up and had the drive pulley running the direction. Pump doesn't work like that.
just a thought
Gratton
#13 old wrench OFFLINE
old wrench
  • 3 Thanks
  • 3 posts
Posted July 09, 2015 - 08:33 AM
Hello, Porkchop5.
I have repaired many of this for having the same problem, 9 times out of 10 its the Brake Shaft Assemble.
Its a Drive Shaft that go's between the Hydro Pump & the Main Drive Gear inside the Transaxle.
It has Fine Tooth spline on the coupler shaft, and over time, it looses its Grip from Viberation and Stress....and Strips Out the teeth....P/N# Repair Kit 210-3000...Cost $125.00 Bucks
Transaxle does need to be Removed.
Fairly Easy Job, Takes about 5 Hours?
#14 Porkchop5 OFFLINE
Porkchop5
  • 1 Thanks
  • 6 posts
Posted March 06, 2016 - 05:07 PM
Hello, Porkchop5.
Fairly Easy Job, Tannkes about 5 Hours?
Old Wrench just wanted to thank you for your spot on diagnosis of my problem. It was the drive shaft. Picking it up next Saturday. Thanks again!!!
#15 MH81 OFFLINE
Posted March 06, 2016 - 06:11 PM
Fantastic job old wrench.
Great news porkchop!
Glad trigger will ride again.
