Vote for Tractor of the Month
won't start
14 replies to this topic
#1 joey7478 OFFLINE
joey7478
  • 1 Thanks
  • 27 posts
Posted June 30, 2015 - 05:42 PM
son ran out of gas and forgot to turn off switch and now won't start. Did something burn up like coil or something else? Thanks Joey!
  • laurarg3 said thank you
#2 Bolens 1000 OFFLINE
  • 12,947 Thanks
  • 17,309 posts
Posted June 30, 2015 - 05:46 PM
How about a little more information about your engine?
If its a points and condenser system you likely burned the contacts
  • joey7478 said thank you
#3 joey7478 OFFLINE
joey7478
  • 1 Thanks
  • 27 posts
Posted June 30, 2015 - 06:37 PM
12 horse kohler points and condenser Thanks Joey!
#4 Bolens 1000 OFFLINE
  • 12,947 Thanks
  • 17,309 posts
Posted June 30, 2015 - 06:41 PM
Most likely the contacts will need to be cleaned or replaced, the battery is likely drained as well.
#5 joey7478 OFFLINE
joey7478
  • 1 Thanks
  • 27 posts
Posted July 01, 2015 - 11:19 AM
checked points and cleaned them and set gap. Still no spark even held on to coil wire to see if was plug. What else could it be? Thanks Joey!
#6 icpik OFFLINE
icpik
  • 21 Thanks
  • 37 posts
Posted July 01, 2015 - 01:35 PM
Sounds like you need to get out the meters and start checking everything starting at the battery ground, then switch, and wires.  A diagram would help and should be here somewhere.
Don Hayes
#7 David Brown OFFLINE
David Brown
  • 4,408 Thanks
  • 2,387 posts
Posted July 01, 2015 - 02:09 PM
the battery is likely drained.
That's what I was thinking.
#8 Bolens 1000 OFFLINE
  • 12,947 Thanks
  • 17,309 posts
Posted July 01, 2015 - 02:31 PM
Is this electric start or pull start?
Battery is likely drained either way and will need to be charged.
#9 joey7478 OFFLINE
joey7478
  • 1 Thanks
  • 27 posts
Posted July 02, 2015 - 12:36 PM
I can't find a wiring diagram on here can you help? Thanks Joey!
#10 Bolens 1000 OFFLINE
  • 12,947 Thanks
  • 17,309 posts
Posted July 02, 2015 - 12:40 PM
Going to need some model numbers to try and find something....
#11 joey7478 OFFLINE
joey7478
  • 1 Thanks
  • 27 posts
Posted July 02, 2015 - 12:53 PM
Its a 1967 1614 serial number x13938e
#12 joey7478 OFFLINE
joey7478
  • 1 Thanks
  • 27 posts
Posted July 03, 2015 - 10:14 AM
I got it running,change the points and coil. Was wondering did the 67 models have a fuel pump? My gas line come out of tank runs across the back side of engine than go up about three inches into carb. some times when going up hill or sideway it bogs down. Thanks Joey!
#13 MNGB OFFLINE
MNGB
  • 1,093 Thanks
  • 883 posts
Posted July 03, 2015 - 12:55 PM
Hi if its a Kohler yes it should have a fuel pump, the K series had a mechanical pump just below the carb.
#14 joey7478 OFFLINE
joey7478
  • 1 Thanks
  • 27 posts
Posted July 03, 2015 - 06:15 PM
Don't  know if last owner took it off or not. I know he changed engine. On my son cub cadet which also has a Kohler has the tank on top and is gravity fed. Thanks Joey!
#15 KennyP ONLINE
  • 29,556 Thanks
  • 40,539 posts
Posted July 04, 2015 - 05:13 AM
Here's a wiring diagram.
Here's the 1969 Owners Manual.
