Backfiring: duck and cover!
14 replies to this topic
#1 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 30, 2015 - 12:35 PM
Can anyone tell what's going on in this (poor) video?
12 hp Briggs, I have spark, but consistent backfires and no start condition
http://youtu.be/wRNL8U-ABik
#2 glgrumpy OFFLINE
  • 8,612 Thanks
  • 7,920 posts
Posted June 30, 2015 - 12:39 PM
Flywheel key? Points adjust?
#3 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted June 30, 2015 - 12:51 PM
Sounds like ignition or improper valves clearances/seating
What model engine?
#4 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 30, 2015 - 12:54 PM
281707
12hp L-head one cylinder
Grumpy, the flywheel key looked good when I had it out, but I can check that again
Bolens, as I'm working through the L-head engine manual something struck me. I lined up the camshaft timing mark with the crankshaft key. Should there be a different timing mark on the crankshaft gear? Maybe my timing really is off
#5 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted June 30, 2015 - 01:10 PM
The way your engine is acting it definitely points towards timing as an issue
Have you had this engine apart? If so you could have been a tooth or two off the mark
#6 boyscout862 OFFLINE
  • 12,859 Thanks
  • 9,173 posts
Posted June 30, 2015 - 01:56 PM
Sometimes a sticking valve can be the problem.
#7 olcowhand OFFLINE
  • 41,193 Thanks
  • 31,428 posts
Posted June 30, 2015 - 02:17 PM
Most every engine I've ever worked on had a dot on both the crank gear and camshaft gear.  Sometimes it will be an angle cut on the matching teeth.  It's either cam timing off or a sheared flywheel key.
  • Alc and aevansgatech have said thanks
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted June 30, 2015 - 03:04 PM
I agree.
  • aevansgatech said thank you
#9 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 30, 2015 - 09:16 PM
Alright I found the problem!
Pulled the engine again, checked the timing gear and camshaft and sure enough there is a tiny timing mark on the timing gear. I had it aligned with the key and not the timing mark so I was at least 30 degrees off
It's looking promising that tomorrow she might finally come back to life!
  • olcowhand, MH81, EricFromPa and 1 other said thanks
#10 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted July 01, 2015 - 07:07 PM
Alright fellas, progress!
She fired up for the first time in many years. Not the smoothest start, but I did have it running for longer.
http://youtu.be/XVT5WNALzP8
I had to disconnect the spark stop wire to get it to start, so I'm sure that wire is chewed up
I also don't have the drive belt connected, so the engine was just spinning freely. Seems like I need to make a couple carb adjustments too
  • olcowhand and alec have said thanks
#11 MH81 OFFLINE
Posted July 01, 2015 - 08:53 PM
Sounds pretty good,
Like you said, a few things to work out, but it RUNS. :dancingbanana:
#12 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted July 01, 2015 - 09:39 PM
glad to hear it ! congratulations  :thumbs:
#13 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted July 10, 2015 - 07:00 PM
Ok so it's running better.. But not great...
I still have a problem with my ignition armature ground wire. I have to unplug it to get spark and to start the tractor. I debated changing it but I tested it with a multimeter and found no resistance across it so it should be ok.
Stuck.. ?
#14 MH81 OFFLINE
Posted July 11, 2015 - 06:23 AM
What wire are we talking about? The one that ends up at the key switch?
When you say won't start, won't roll over or no spark?
#15 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted July 11, 2015 - 08:34 AM
The wire going from the ignition armature to ground (near the governor)
When I have it unplugged, the engine will start
When I have it connected, the engine will turn but has no spark
