OK guys....I've got the trans all apart. 2nd gear was always jumping out of gear and shifter rod became extremely sloppy all the sudden. Anyone replace any gears in these old machines? Is it worth it? Do other rear ends fit? Just wondering if its worth the time. Any advise? Seems like most the gears have tapered edges. Couple are reversible but most aren't.
mf7 trans/rearend questions....
Started by
fishingbud
, Jun 29, 2015 08:42 PM
3 replies to this topic
#1
OFFLINE
Posted June 29, 2015 - 08:42 PM
- laurarg3 said thank you
#2
OFFLINE
Posted June 29, 2015 - 08:54 PM
How are the shifter DETENTS?
They hold the trans in gear, if there not stiff or firmly holding the shifter in position then most likely that's the problem or the cause of the problem.
Can you post some pictures of the gears?
#3
OFFLINE
Posted June 29, 2015 - 10:12 PM
The detents seem OK sliding on the shaft....I'll get pics tomorrow... all I have is general pics for Assembly
#4
OFFLINE
Posted July 01, 2015 - 05:41 PM
Hi, I see your from Wisc, if you need a parts tractor there are a couple on Craig's list in Minnesota and Wosconsin.
