If you were installing new blades on your deck, would you put the regular blades on or mulching ones. This tractor does not or ever use the mulching kit on it to collect the grass. Just wondering if the mulching ones are any better for cutting or worse. Thanks, any input would be great. Noel
what type of blade to use ?
#1
ONLINE
Posted June 29, 2015 - 04:58 PM
- pharmer said thank you
#3
ONLINE
Posted June 30, 2015 - 03:15 AM
I put Gators on My JD and it cut more grass and made even bigger wind-rows, which I was trying to make less. I found out later you need to have mulcher block for the outlet for those blades to work. That on mine is a plastic thing that I never have been able to put on and make it fit and stay correctly. I now have just the reg JD blades again. My PK cuts much finer and I use that on yard now more than the JD. I have even followed the JD with Wife on it with my PK and cut up here windrows and not needed to sweep then, much better.
- Alc and propane1 have said thanks
#4
ONLINE
Posted June 30, 2015 - 05:35 AM
Seems like you need to find out how the blades work on a certain model ( deck too ) before knowing if they are any good . I did a search for my tractor because in the fall I put a piece of sheet metal over the chute to mulch the leaves but I couldn't find any .Unless you have to go by blade hole length instead of tractor model mine's a JD 318 w/50" deck
#5
ONLINE
Posted June 30, 2015 - 07:14 AM
I run the Gator blades on my 48" deck on a JD F525 with the deflector removed. The end of the deck is completely open and it blow grass out about the width of the last pass. No windrows, no bunching, no re-cutting. Picks up the front idler wheel tracks nice also. A BIG key as to how a deck will work is how CLEAN it is underneath. Keep it clean, either by power washing, with a hose or just scrape it out but keep it cleaned out and your deck will do a much better job of mowing.
- Alc said thank you
#6
ONLINE
Posted June 30, 2015 - 08:17 AM
I had the gators on my Sears, didn't like them at all. Didn't seem to get enough lift to cut properly, horrible when I tried to cut the taller field grass. I know other guys using them on their Sears, they love them. I will stick to my factory blades on my Suburbans
#7
ONLINE
Posted June 30, 2015 - 06:35 PM
I use one that cuts the grass!
#8
ONLINE
Posted June 30, 2015 - 07:27 PM
Eric
Edited by dropped82, June 30, 2015 - 07:28 PM.
#9
ONLINE
Posted June 30, 2015 - 07:42 PM
Mulching Blades are only good if your deck was mulching compatible. The mulching occurs when you get enough air lift to recirculate the grass in the deck longer, if you have a regular shallow deck that originally didn't come with mulching blades as an option the blades will do you no good.
- Alc and TAHOE have said thanks
