Wanted
Weight Distribution Hitch
10 replies to this topic
#1 KC9KAS ONLINE
KC9KAS
  • 5,078 Thanks
  • 4,479 posts
Posted June 29, 2015 - 03:42 PM
Looking for a used weight distribution hitch.
Shouldn't have sold mine with the travel trailer! :wallbanging:
#2 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted June 29, 2015 - 04:28 PM
Never used one.Do they make a big difference? Do they have to be somewhat sized for the load you are hauling?
#3 KC9KAS ONLINE
KC9KAS
  • 5,078 Thanks
  • 4,479 posts
Posted June 29, 2015 - 06:29 PM
Yes, they make a BIG difference, and yes, you need to adjust for the amount of load you have.
An anti-sway attachment is also a must item.....BUT...be sure to remove this item before backing the trailer...Not much problem straight, but the anti-sway attachment can double up when backing and turning. A friend warned me about this, and I have always removed mine if backing.
#4 poncho62 ONLINE
poncho62
  • 999 Thanks
  • 1,352 posts
Posted June 29, 2015 - 06:30 PM
Get a 5th wheel, dont need any of that crappola
#5 MH81 ONLINE
  • 29,203 Thanks
  • 29,414 posts
Posted June 29, 2015 - 08:49 PM
Had one on the stock trailer. Got rid of it too.
Always found that I could counter most of that by shifting the load when needed.
#6 adamjd200 ONLINE
adamjd200
  • 1,755 Thanks
  • 1,907 posts
Posted June 29, 2015 - 09:47 PM
Never used one, no one I know uses one, can't help you there.
#7 Alc OFFLINE
  • 6,054 Thanks
  • 6,972 posts
Posted June 30, 2015 - 05:39 AM
Maybe try RV dealers to see if they have any used ones or try calling some campgrounds .  I have an extra but those things are so heavy to ship I'm sure you can find one near by
#8 chieffan ONLINE
  • 7,526 Thanks
  • 5,317 posts
Posted June 30, 2015 - 07:18 AM
They definitely are a big help when pulling any of the larger size campers or trailers.  I forget the brand of the one I had but it had the two weight distribution bars and sway bars all in one.
#9 CRFarnsworth ONLINE
CRFarnsworth
  • 3,893 Thanks
  • 1,825 posts
Posted June 30, 2015 - 08:25 AM
I've got two.   Too bad I didn't know sooner.
You could have got them when you were up this way picking up  a Choremaster.
Sent you a couple P.M.s                         Rick
#10 Billy M ONLINE
Billy M
  • 490 Thanks
  • 451 posts
Posted June 30, 2015 - 03:28 PM
I have a spare if you are going to be around the Dayton, OH, area any time soon.  It's just the receiver though, no bars, brackets, chains, etc.
#11 chieffan ONLINE
  • 7,526 Thanks
  • 5,317 posts
Posted October 27, 2015 - 07:06 AM
Who wants to climb a set of stairs to get in thing.  And then another set to get to the bedroom where you can't stand up.  And then push a sheet of plywood down the road over the cab of your tow vehicle.  Would never own a 5th wheel to use.  Last one I had I junked out and made a hay trailer out of the frame and wheels.  Our camper is the older style and has one step between the ground and camper floor.
