Roof Ranger mower
9 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 163 Thanks
  • 273 posts
Posted June 29, 2015 - 01:54 PM
Is this mower worth restoring? I can get it for $50. Doesn't run I was told. Can u get parts or decals for it? I read where they were made in Pontiac,Illinois. I wonder what year it is?
Thanks
  • Traill95 said thank you
#2 Dane in PA OFFLINE
Dane in PA
    Dane in PA
  • 531 Thanks
  • 601 posts
Posted June 29, 2015 - 02:15 PM
I wouldn't restore it.  Clean it up and get it going.  Parts are going to be NLA unless you can cross it somewhere else.
#3 Bill 76 OFFLINE
Bill 76
  • 1,689 Thanks
  • 1,082 posts
Posted June 29, 2015 - 03:54 PM
Get the numbers of the engine and that may help date it
#4 glgrumpy ONLINE
  • 6,805 Thanks
  • 6,597 posts
Posted June 29, 2015 - 04:29 PM
I see the big ones at shows all the time, very few if any of these smaller ones.  Think value-wise is great buy for rarity.  The engine will not be hard to fix, just a Briggs. Anything else depends on whether they used generic off the shelf bearings and shafts and such or if all specific made. I bet just good cleaning and repair would make it work. Fix the engine to get running first, then oil up all the drive stuff and let soak long time before trying it out. Might need to replace a chain or belt or such if rusted up or torn. Think it would be neat project, long as you don't get frustrated early working on the problems and lack of info on them. IF you need something quick to use, Don't buy it. If you just want something to play with and can take time, go for it. I don't believe this is all that old. The company used modern twin engines in those bigger units, some had a jeep like body on them and some not.  I see them at shows here in INdiana lots of times, so they are out there.
  • Alc and grattone have said thanks
#5 Bmerf OFFLINE
Bmerf
  • 1,740 Thanks
  • 1,457 posts
Posted June 29, 2015 - 04:30 PM
:welcometogttalk:
I'd get it. Neat little mower, shouldn't be to hard to get going. If the motor is indeed bad, a replacement could come from any lawn mower.
#6 grattone ONLINE
grattone
  • 233 Thanks
  • 177 posts
Posted June 29, 2015 - 07:16 PM
post-66237-0-85405500-1435622578_thumb.jpost-66237-0-26256000-1435622431_thumb.j
I have a walk behind version that I bought new in 1974, as you can see the deck rusted out while it was setting for a number of years. Last winter I repaired the deck and have use it a number of times to mow a steep bank at the in-laws. The only part that should be a problem is the drive wheel in the first picture and I have been told that a drive wheel for the older snapper mowers will work ( never checked to see if that is true). I worked on them in the late 60's at a lawn mower repair shop they are good units. I will try to get some better pictures tomorrow.
Good Luck
Gratton
#7 grattone ONLINE
grattone
  • 233 Thanks
  • 177 posts
Posted June 29, 2015 - 07:24 PM
http://www.collector...ini-jeep-mower
This is the unit glgrumpy is speaking of as the large ones
#8 Traill95 ONLINE
Traill95
    Traill95
  • 1,607 Thanks
  • 930 posts
Posted June 29, 2015 - 09:01 PM
That is the only Riding mower that my dad owned. It was fun to drive and if you leaned back a little you could  pop a wheelie. Just didn't do it in front of dad. :D
#9 coinman66 OFFLINE
coinman66
  • 163 Thanks
  • 273 posts
Posted July 01, 2015 - 06:46 AM
Wonder if I can find a service\parts manual for it?
#10 coinman66 OFFLINE
coinman66
  • 163 Thanks
  • 273 posts
Posted July 02, 2015 - 12:52 PM
Engine dates it to 1982. So now I wonder if they made them up to 1982?
