Wheels...Help!
7 replies to this topic
#1 Cattle-Dog OFFLINE
Cattle-Dog
  • 19 Thanks
  • 10 posts
Posted June 28, 2015 - 10:00 PM
So as I posted a few months ago, I purchased an LGT16D.  Overall it is in good shape, but needed some TLC in certain places.
The first place I started was tires.  They seemed original, were dry rotted, and all 4 leaked.  The rears were not that big of a deal.  Bought some 6 ply's and had them mounted.  Done deal.
The fronts... oh man, the fronts have been a living nightmare.  The first one did not want to come off (rust in the spindle), but I was finally able to convince it.  However, it has a lot of rust around the valve stem on the rim.  A lot.  So I set it aside and worked on the next one.  I cannot get it off the spindle!  I assume more rust, but its much worse!
I have beat it with a soft mallet, pulled, yanked, screamed, yelled... Then I upped the ante.  Didn't want to use open flame with the all the grease in the area, but put a high end heat gun to the hub until the bearings were starting to smoke.  Still won't budge.  Finally, I pulled the valve stem and broke the outside bead of the tire while it was all mounted.  Then I put a big set of gear pullers on it attached to the rim.  It still would not budge! I tightened the pullers until the rims were warping and beat the back side of the rims with a mallet. Still not go!  So tightened up the gear puller more (with an pneumatic impact!!) and put a spud bar against the back of the rim, coming through the other side, and hit it with a sledge hammer.  I've been doing this all night and it's only moved 1/4"!!
One, any suggestions for getting this POS rim off the spindle?
Two, I may have or will end up having ruining the rim, plus the one that came off had a lot of rust around the valve stem.  I looked up the part number for new front rims (SBA450140440).  But I can't find them ANYWHERE! Does rims from anything else fit? I assume LGT14D, but its the same part number.  What about other LGT models or even non Ford/Holland rims?
Thanks in advance.
Chad
#2 boyscout862 OFFLINE
  • 13,446 Thanks
  • 9,392 posts
Posted June 28, 2015 - 10:33 PM
You should be able to find rims based on the diameter, widths, spindle diameter, and offset. I usually check places like https://www.surpluscenter.com/  and  http://www.baileynet.com/  . There is a place on EBAY that specializes on wheels and tires from TN. Good Luck, rick
#3 chieffan OFFLINE
  • 10,946 Thanks
  • 6,941 posts
Posted June 29, 2015 - 06:58 AM
What are the dimensions of the rims? Need the rim width, diameter, offset and bore size. Have a friend that is a Ford gatherer that may have something that would work. May not be an exact match but would work in a pinch.
Edited by chieffan, June 29, 2015 - 06:58 AM.
#4 KennyP OFFLINE
  • 40,192 Thanks
  • 46,794 posts
Posted June 29, 2015 - 07:20 AM
Are the spindles 1" on that? The reason I ask is the bearings for it are '25MM' in size. Maybe some JD rims might work?
#5 toppop52 ONLINE
toppop52
  • 5,458 Thanks
  • 4,866 posts
Posted June 29, 2015 - 07:43 AM
Front wheels tend to not be unique to a brand or model, tire dealers/wholesalers, tractor supply houses, etc... will be able to get nearly any rim.
#6 Cattle-Dog OFFLINE
Cattle-Dog
  • 19 Thanks
  • 10 posts
Posted June 29, 2015 - 12:06 PM
Those are the sort of things I was hoping to hear.  The bearings are in fact:
BALL BEARING,25mm ID x 52mm OD x 15mm W
The tires are 16x6.5-8.  So I believe they are 8" rims and are 6.5" wide.  Not sure on the offset.  I'll have to measure.  I don't think it is far from 0.
#7 Cattle-Dog OFFLINE
Cattle-Dog
  • 19 Thanks
  • 10 posts
Posted June 29, 2015 - 01:36 PM
I did find out that John Deer wheel part AM102887 is a 6.5x8 wheel that uses the same bearings.  What I don't know is it's offset and if there is a major difference in hub length, so that the bearings actually sit on the spindle and the castle nut actually retains them.
#8 Cattle-Dog OFFLINE
Cattle-Dog
  • 19 Thanks
  • 10 posts
Posted July 01, 2015 - 09:29 AM
So here is a question.  Being as this tractor is still essentially built in Japan, the Shibaura GT161, has anyone been successful in find or importing parts for it?
