Replacing 18 hp opposed twin with 14 hp Vanguard?
16 replies to this topic
#16 Diesel1050 ONLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted July 02, 2015 - 05:27 PM
Went ahead with the swap. It is going to be much more useful now. Some things need to be adressed, such as a new mounting plate, stationary pully for the PTO, and it needs a starter. It will have to be mounted off to one side so the driveshaft doesn't interfere with the steering column. Also I have found a way to make my belt drive Simplicity snowblower work on this tractor. uploadfromtaptalk1435875873716.jpg uploadfromtaptalk1435875913487.jpg uploadfromtaptalk1435875973987.jpg uploadfromtaptalk1435876007467.jpg
#17 Diesel1050 ONLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted July 02, 2015 - 05:30 PM
Also now that it has a motor that is slightly smaller and easier to "move", could I potentially cut, bend, and weld the frame so It is straight and not bent to clear the old motor?
  • Cvans said thank you
