sticking in reverse
2 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted June 27, 2015 - 10:19 PM
B112 sticks hard in reverse .checked gear oil, oiled moving parts , was kinda sticky all around at first but after oiling and working it a bunch it shifts good but I have to smack it to get it out of reverse ( not good ) any thoughts ?
  • laurarg3 said thank you
#2 boyscout862 ONLINE
  • 13,557 Thanks
  • 9,431 posts
Posted June 28, 2015 - 05:45 AM
Adjust the drive belt. The guide on the idler pulley is critical to have it at an angle that stops the belt. If that doesn't fix it, check that the clutch rod isn't holding the shift rod. Good Luck, Rick
  • Alc and alec have said thanks
#3 MH81 OFFLINE
  • 29,979 Thanks
Posted June 28, 2015 - 05:55 AM
:ditto:
Also, check to make sure the brake isn't to tight.
My 112, it doesn't shift well if my vari-speed is lower than about 4. Try shifting in a higher number.
  • alec said thank you
