New toy....1965 Jeep CJ-5
16 replies to this topic
#1 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted June 27, 2015 - 05:56 PM
Picked up this one for $300, came with a plow, pto winch, and full steel cab. Runs and drives, but needs a lot of work. Pulling the tub tomorow and am going to pretty much restore it! Comments? Opinions? Fried dough?uploadfromtaptalk1435445765501.jpg uploadfromtaptalk1435445808733.jpg
  • Gtractor, wvbuzzmaster, middleageddeere and 5 others have said thanks
#2 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted June 27, 2015 - 06:04 PM
AH! What patina! Good luck!
  • tinbender7 and boyscout862 have said thanks
#3 propane1 ONLINE
propane1
  • 9,740 Thanks
  • 4,516 posts
Posted June 27, 2015 - 06:36 PM
What a deal. And a real jeep, compared to today's jeeps. Noel
#4 olcowhand ONLINE
  • 43,162 Thanks
  • 32,011 posts
Posted June 27, 2015 - 06:45 PM
Straight six?  Can't beat the old Jeeps.  I had a 58 Willy's years ago, and a 70ish CJ5 but the body was literally falling off the frame.  I found a CJ7 body, so did a rebuild as a 7.
#5 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted June 27, 2015 - 06:56 PM
Nope....straight 4. It is a Jeep F-134 Hurricane motor, with a 3 speed stick, twin stick transfer case for the PTO winch, and 4 hi/lo.
  • olcowhand, Team_Green and propane1 have said thanks
#6 stiemmy OFFLINE
stiemmy
  • 2,538 Thanks
  • 1,830 posts
Posted June 27, 2015 - 07:16 PM
I'd say ya done really good with that buy!! Not only was the price right , but she doesn't look too bad from here. The value of jeeps has gone sky high, and collectors go nuts for em. Thank you for sharing with us, and good luck on your project. Cheers!!
#7 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted June 27, 2015 - 07:20 PM
The tub is gone to you know where, might need the side of a box truck to fix all the holes! Rear spring mounts are broke in usual spots for these, which isn't a problem! Can't wait to wheel it and push some snow!
  • propane1 said thank you
#8 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 11,123 Thanks
  • 6,477 posts
Posted June 27, 2015 - 09:09 PM
That brings back many good memories
I don't remember much techinal specs. Dad had a 60s cj5. We had such fun in that thing.
Please keep us updated on your pro gress
#9 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted June 27, 2015 - 09:18 PM
Sure will! My neighbor is currently building a 92' Wrangler, and has a 98' Cherokee for parts (Motor, Trans, and Axles) and said if I helped him pull the motor, I could have everything else off the parts one! List of stuff coming off of that is the following: Seats, Gas Tank, Radio, Speakers, Leaf Springs, Shocks, Window Motors, Floorboards, Various Body Panels, and the Front and Rear Bumpers!
Edited by Diesel1050, June 27, 2015 - 09:19 PM.
#10 Bill 76 ONLINE
Bill 76
  • 2,015 Thanks
  • 1,208 posts
Posted June 27, 2015 - 11:45 PM
Wow what a deal,My dad had a new 1961 jeep but I think it was a Willys ----man that thing was a blast it would go through anything.
#11 Jazz OFFLINE
Jazz
  • 2,707 Thanks
  • 1,566 posts
Posted July 13, 2015 - 05:26 AM
Other than the tub the rest of the truck looks pretty decent. Lots of good parts. Hope the frame is solid.  My brother inlaw put a volkswagen diesel into a vintage jeep. I recall it had a pto at rear of tub.
Edited by Jazz, July 13, 2015 - 05:27 AM.
#12 js5020 ONLINE
js5020
  • 716 Thanks
  • 810 posts
Posted September 16, 2015 - 07:36 PM
Gotta love them CJs,,, I have a 79 CJ5 in the shop now getting a going over in prep to be my new daily driver.  Any updates on your progress?
  • Diesel1050 said thank you
#13 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted September 16, 2015 - 07:55 PM
As a matter of fact I do! The only thing left of the CJ is the plow setup. Traded the rest minus a few parts for a bunch of Sinplicity attatchments. Oh and spent a grand on this ..1968 Jeepster, it has 38.5 Super Swamper Irok's on 15x12 beadlock rims, front and rear lockers, a 3 speed stick, and a 2/4 hi/lo transfer case.
Aaaaaaand a 400 hp V-6!
Upgrades to motor listed below....total in its lifetime it has had about 10 grand done to it! It is a Dauntless 225 V-6, built by buick for Jeep, then Jeep bought it out.
Fully rebuilt,
bored .30 over,
Summit racing pistons & con rods
Buick 231 crank conversion & bearings
Aftermarket high-comp rings
Clifford Performance (6=8) heads
All new gaskets
Isky cams
Isky Hydraulic lifters
E3 plugs
Ford Racing plug wires
HEI distributor
2 brl Offenhauser intake
Offenhauser spacer block
4 brl Edelbrock 750 cfm Carb
Summit racing water pump
Summit racing alternator
Summit racing starter
K & N filter(s)!
Machined oil sumps
6=8 high-flow headers (2") w/ 5" tips out sides under cab!
Future plans are to add a FULL rollcage to the engine area, cab, and two down the back of the bed. Also going to install an onboard air and power system, put on a 12,000 pound Rough country winch, some bilstien shocks, leaf springs from F-250, and new lift brackets! Lift will be about 14 inches and paired with the tires and spring over conversion i'm doing on the axles, a new pitman arm will be in order, if not fully hydraulic steering!
.uploadfromtaptalk1442450362931.jpg uploadfromtaptalk1442450394785.jpg uploadfromtaptalk1442450427934.jpg
Edited by Diesel1050, September 16, 2015 - 07:57 PM.
#14 js5020 ONLINE
js5020
  • 716 Thanks
  • 810 posts
Posted September 16, 2015 - 08:38 PM
Wow sounds like a real mud bogger.  My first Jeep was a 65 CJ5, pretty stock except for the GM power steering setup and a stock SBC.  Had to get rid of it once kids came into the equation, but now the last one has graduated and soon I'll be back into a CJ5.  This one should have better daily drivability and more heat than the 65.
#15 toppop52 OFFLINE
toppop52
  • 5,596 Thanks
  • 4,941 posts
Posted September 17, 2015 - 06:25 AM
They're cool trucks, but be careful of that short wheelbase.They will lay down if you give them a chance, but they'll go places a pack mule won't.
