How to fix a bad exhaust outlet
11 replies to this topic
#1 Gfann OFFLINE
Gfann
  • 194 Thanks
  • 228 posts
Posted June 27, 2015 - 04:43 PM
I need some pointers on how best to get an exhaust on this K181, off a Speedex S18.
  • tinbender7 said thank you
#2 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,288 Thanks
  • 9,776 posts
Posted June 27, 2015 - 04:53 PM
I could tell you every idea I every heard second hand , but I am going to wait for someone who really knows his stuff to tell you.
  • propane1 said thank you
#3 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted June 27, 2015 - 05:03 PM
With some O/A heat and lots of luck you might get the old studs out. With all the pitting I don't know if it will ever be leakproof.
Mike
#4 poncho62 ONLINE
poncho62
  • 1,733 Thanks
  • 1,659 posts
Posted June 27, 2015 - 05:41 PM
I would clean up those pipe threads in the exhaust hole and thread a pipe in there.
  • tinbender7 and boyscout862 have said thanks
#5 Gfann OFFLINE
Gfann
  • 194 Thanks
  • 228 posts
Posted June 27, 2015 - 05:43 PM
Those pipe threads are not usable. They are gone most of the way around.
#6 olcowhand ONLINE
  • 41,086 Thanks
  • 31,402 posts
Posted June 27, 2015 - 05:45 PM
Yep, me too.  To do it right, you'll need a NPT  pipe tap of the appropriate size.   Make sure engine is turned until the exhaust valve is closed, as you'll wanna blow out the crud from tapping several times during the process.  Tap it slow, backing it out often to blow crud blow out.  It may look like the threads are gone, but they are filled with rust & crud.  The tap can make them usable again.
  • poncho62, tinbender7, Cvans and 3 others have said thanks
#7 Gfann OFFLINE
Gfann
  • 194 Thanks
  • 228 posts
Posted June 27, 2015 - 05:55 PM
Sounds like a good way to go. Thanks Guys.
#8 olcowhand ONLINE
  • 41,086 Thanks
  • 31,402 posts
Posted June 27, 2015 - 05:58 PM
Oh, another thing.  The pipe tap may have to go in a good ways, and IF the pipe you put in wants to bottom before it snugs at the edge of the hole, then you'll need to cut off a couple threads at a time off the end of the new pipe until it goes in good & snug.  If you don't have all threads contacting good, then the pipe can & likely will work itself loose.
  • tinbender7, Cvans, Gfann and 1 other said thanks
#9 WHdbJD ONLINE
WHdbJD
  • 686 Thanks
  • 515 posts
Posted June 27, 2015 - 06:08 PM
Ive used a shop vac instead of compressed air to clean the "crud" from the threads.  I still keep the exhaust valve closed,
but using the shop vac keeps the crud  out of my face/eyes.
  • boyscout862, Gfann and propane1 have said thanks
#10 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted June 27, 2015 - 07:10 PM
Vacuum works good...Some grease on the tap will also help keep the bits of metal out of the exhaust port.
Slow & steady with the tap...back & forth.
  • WHdbJD and propane1 have said thanks
#11 Alc OFFLINE
  • 6,884 Thanks
  • 7,459 posts
Posted June 28, 2015 - 06:15 AM
If going with the tap repair , would it be wise to try getting as much rust out of the threads before running the tap in ? The metal around the exhaust looks so thin
#12 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted June 28, 2015 - 07:43 PM
That would be a good idea, as that would also aid in getting the tap started straight.
