Turbo for G1900
3 replies to this topic
#1 Guenther OFFLINE
Guenther
  • 1 Thanks
  • 2 posts
Posted June 27, 2015 - 07:09 AM
Has any one installed a Turbo on a Kubota G1900
  • mattakuboturbo said thank you
#2 farmtoybuilder OFFLINE
farmtoybuilder
  • 13 Thanks
  • 27 posts
Posted August 17, 2015 - 09:35 AM
No but it wouldn't be hard too! We had one on B-7200 4wd with D950 motor that we pulled with. Japanese engineers got a kick out of it when we fired it up! Turning 6500-7000 rpms.
Edited by farmtoybuilder, August 17, 2015 - 09:36 AM.
#3 mtoney OFFLINE
mtoney
  • 830 Thanks
  • 693 posts
Posted August 17, 2015 - 08:51 PM
The turbo/manifold assembly from a Euro spec Smart car is almost a bolt up fit for the older D600 and its varients used in Cub Cadets and Kubotas, seen that done a few times.   Its also a small enough turbo to actualy build boost.  Prior to that the only real small turbos was from a couple motorcycles and the little diesels dont move enough CFM of air to build boost with those.  If you do go for it, make sure to put a pyrometer in the exhaust so you dont have a meltdown under boost, or lift the head and blow the gasket.  Mike
#4 mattakuboturbo OFFLINE
mattakuboturbo
  • 1 Thanks
  • 1 posts
Posted December 27, 2017 - 04:24 PM
hello i am working little turbo  on my g 1900,and cylinder will be ported and do new header,about stainless steel .from finlandbw marko
