Fixing LJ on the trailer
12 replies to this topic
#1 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,812 Thanks
  • 4,305 posts
Posted June 27, 2015 - 03:29 AM
My solution to fix Little John on the trailer. Backwards it's fixed w/ a tension belt. I only need two wooden logs (10/4/4 inches) in front of the tires and voilá - ready
edit: sorry, forgot the pics...
Edited by jd.rasentrac, June 27, 2015 - 03:31 AM.
  • MH81, Alc, CRFarnsworth and 3 others have said thanks
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 27, 2015 - 05:58 AM
Looks good. Is that ABS pipe? I usually chain the back end of mine down to the anchors in the trailer and then strap the front down over the axle. I also add a small strap over the hood to keep it from flying up in the wind.
  • jd.rasentrac said thank you
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,812 Thanks
  • 4,305 posts
Posted June 27, 2015 - 06:22 AM
Pardon Brian,  what`s ABS? It's a plastic pipe, light and easy to handle. First I thought to take a steel pipe, but it's to heavy. In former times, I fixed the gt front axle, but then, I damaged the steering and so I found this solution.
Edited by jd.rasentrac, June 27, 2015 - 06:23 AM.
  • HDWildBill said thank you
#4 shorty ONLINE
shorty
  • 5,840 Thanks
  • 5,421 posts
Posted June 27, 2015 - 06:38 AM
A neat way to keep him in place. And a place to keep small things in the front.
#5 MH81 OFFLINE
  • 29,979 Thanks
Posted June 27, 2015 - 06:54 AM
Looks like a nice solution.
Being plastic, will they hold up in a panic stop or impact?
Here is a link that explains two of the most common plastic pipes used over here.
http://www.diffen.co...ence/ABS_vs_PVC
#6 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,812 Thanks
  • 4,305 posts
Posted June 27, 2015 - 10:21 AM
Therefore I'll place the two logs in front of the tyres. The forces were conducted in thee frontwall and the frame of the trailer. I've tested the construction and it works. :thumbs:
Edited by jd.rasentrac, June 27, 2015 - 10:26 AM.
#7 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,812 Thanks
  • 4,305 posts
Posted June 27, 2015 - 11:12 AM
Can be ABS. It's not so hard and fragile like PVC.
  • JDBrian said thank you
#8 Jazz OFFLINE
Jazz
  • 2,679 Thanks
  • 1,550 posts
Posted July 03, 2015 - 04:01 PM
I use PVC for guides on my boat trailer and I have broken a few in windy conditions over the years.. I tie my tractor axle to 3/8th eyebolts that are through frame of trailer. The rear is anchored to tractors hitch,,nothing ever moves. Are you concerned with scuffing paint on your tractor,,,looks very pristine. You could wrap a rag(or a silk scarf) around axle and then put strap on it..Thats a very nice tractor!.
Edited by Jazz, July 03, 2015 - 04:04 PM.
#9 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted July 03, 2015 - 04:07 PM
I throw straps everywhere that gains me tension needed to unitize tractor to trailer. But I don't worry about scuffing the paint verses losing a tractor... Which is way tougher to touch up with a can of paint. Looks like a good solution for you.
#10 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,812 Thanks
  • 4,305 posts
Posted July 04, 2015 - 11:07 AM
Okay, tomorrow I'll drive to an event and so I had to load today - 35 °C in the shadow here this time. 95 °F is too much for a North Hesse!
No matter, I had ti fix Little John on the trailer and now, I think, he's fixed!
  • olcowhand and KennyP have said thanks
#11 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,812 Thanks
  • 4,305 posts
Posted July 04, 2015 - 11:12 AM
Tractors are made for use - and everyone can see, that LJ isn't brand new. Thanks, I like my 112, too! And i think, the Gator and the 112 are a good "harnessed team"!
Edited by jd.rasentrac, July 04, 2015 - 12:06 PM.
#12 HDWildBill OFFLINE
  • 8,984 Thanks
Posted July 04, 2015 - 12:19 PM
Nice solution to the problem, Wolfgang.  I don't think you will have any problem with LJ in there. :thumbs:
#13 KennyP OFFLINE
  • 41,032 Thanks
  • 47,165 posts
Posted July 04, 2015 - 04:09 PM
LJ looks like he will enjoy the ride!
