* * * * * 1 votes
Cub Cadet 108 Purchase and Repairs
32 replies to this topic
#31 dodge trucker ONLINE
dodge trucker
  • 2,711 Thanks
  • 3,357 posts
Posted September 30, 2015 - 05:34 AM
I will have to get back to you on that, I do not have it here right now.
I know that I can use a steering column to start off with from the 129. Mine was run w/o an upper bushing so long, thta it is "flared-out" at top of the tube the steering shaft goes in. I was wondering if I could cut about an inch-inch and 1/2 off and put a bushing/bearing there and still be OK.... it would still stick out of the dash plenty.
Edited by dodge trucker, September 30, 2015 - 05:37 AM.
#32 lrhredjb ONLINE
lrhredjb
  • 804 Thanks
  • 617 posts
Posted October 01, 2015 - 02:19 PM
I took the front spindles off of the 108 tonight. Going to have to replace the kingpin bolts and repair or replace the bottom hole of the left spindle. I had a major toe out issue and when I jacked it up to make it easy to adjust the tie rod the spindles relaxed more that I like to see... Ever.
In fact, the toe out created a bad situation because I always watch the left front tire going up ramps, and the front slid off the ramps to the right. (toe out meant it pulled to the right) Luckily no bad things happened (font end dropped onto the right ramp) and we loaded it by shoving it on the trailer, no driving. Anyway, watch for toe out when buying tractors guys. It might not give bargaining room, but it might keep you safely upright while loading.
This is a new one on me, how do you replace a hole??
#33 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted October 01, 2015 - 05:51 PM
Entire spindle was bent, so had to replace it.
