New Tires, Wow What a Difference!
5 replies to this topic
#1 toppop52 OFFLINE
toppop52
  • 4,714 Thanks
  • 4,432 posts
Posted June 26, 2015 - 08:29 PM
I'll get pics tomorrow, but I couldn't believe the difference. When I swapped for my 4041 front end loader, it had a set of rear tires off a garden tractor on the front, 23/10.50/12" with a max inflation of 15 psi. It was like steering a pair of ships rudders through marsh mud! I found the proper size 20.5/8/10" on solid steel white wheels with 5/4.5" bolt pattern. Ten ply, 90psi max and 1535 lbs each, payload rating. The wheels are reversible with about a half inch difference in offset from side to side. They were at ATD ( American Tire Distributors) warehouse, we have huge mid Atlantic warehouse in Salisbury. I can buy directly from them because of my business connections. $57 each for the wheel/tire combo. Now the tractor, even with a load in the bucket, almost feels like power steering, wow what a difference!
Edited by toppop52, June 26, 2015 - 08:30 PM.
  • olcowhand, Gtractor, MH81 and 8 others have said thanks
#2 Lmiller3358 OFFLINE
Lmiller3358
  • 1,466 Thanks
  • 1,412 posts
Posted June 27, 2015 - 05:21 AM
Great deal, good luck with them
  • toppop52 said thank you
#3 KC9KAS OFFLINE
KC9KAS
  • 5,199 Thanks
  • 4,582 posts
Posted June 27, 2015 - 08:14 AM
Sounds like a good price for the tire/wheel combo. Glad you have something that works for you and your GT/loader!
#4 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted June 27, 2015 - 08:44 AM
Isn't it amazing what a difference in tread can do?
Those old tires are probably best on a snow plow tractor, etc. Happy for you that the new ones are working out well.
The rims; are they stout enough for loader work? So many of the newer rims are such light duty...
I've seen rims buckle under load when a turn happens, our old potatoes digger trashed a pair pretty quick and I wouldn't even call it heavy. Wouldn't want that to happen with a load up.
#5 toppop52 OFFLINE
toppop52
  • 4,714 Thanks
  • 4,432 posts
Posted June 27, 2015 - 02:30 PM
The tires are Chinese Hi-Run 10 ply rated for 1535 lbs each, the rims are American made and rated for 2000 lbs each. No guarantee they won't give it up, but they seem OK.
#6 toppop52 OFFLINE
toppop52
  • 4,714 Thanks
  • 4,432 posts
Posted June 27, 2015 - 03:01 PM
Wheels are 2 piece with the 2 centers welded together, they're rated for 120 psi tire.
front%20tire%20loader.JPGfront%20tire%20loader%202.JPGfront%20tire%20loader%204.JPGfront%20tire%20loader%203.JPGfront%20tire%20loader%204.JPG
  • olcowhand and KennyP have said thanks
