1963 Ford 2000
15 replies to this topic
#1 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted June 25, 2015 - 09:02 PM
This is a tractor I'm trying to get running, 1963 Ford 2000.
It has the 134 gas engine and I don't know how many decades it sat after it last ran.
Motor has oil, coolant, and cranks over with some compression.
It does fire and try to run but doesn't seem to hit hard enough to run on its own.
Question
What voltage is this suppose to be?
6 volt, 12 volt,
positive ground, negative ground?
  • Alc, Coventry Plumber and laurarg3 have said thanks
#2 Cat385B OFFLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted June 25, 2015 - 09:09 PM
12 volt, negative ground.
How's the distributor look?
  • DH1 and boyscout862 have said thanks
#3 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,315 Thanks
  • 4,951 posts
Posted June 25, 2015 - 09:16 PM
Tractor Data says its positive ground.  Doesn't mention voltage.
I don't have a clue.
I imagine the later 3 cylinder 2000's were 12 volt negative ground but the older 4 cylinders could very well be different.
Edited by Gtractor, June 25, 2015 - 09:17 PM.
#4 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,360 posts
Posted June 25, 2015 - 09:38 PM
Found this:
http://www.yesterday...ctor-Parts.html
  • DH1 said thank you
#5 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,360 posts
Posted June 25, 2015 - 09:39 PM
Here is a kit for a 12 volt conversion
http://www.yesterday...ion-Kit_503.htm
#6 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted June 25, 2015 - 10:24 PM
The correct firing order is 1-2-4-3 if the rotor turns clockwise.
If the rotor turns counter-clockwise, the firing order is 1-3-4-2.
#1 cylinder is closest to the radiator.
#1 terminal on distributor cap should be labeled, but the wires could be installed in different terminals, as long as the firing order is correct.
There should be a small clip between the distributor shaft and the rotor.  ....If this clip is missing, the timing is erratic.
The plug wire connections at the cap are not obvious in your pic.
For some reason, people screw up the firing order on these engines quite often.  ...Engine will usually start, but lack power, or not run properly.
Ford used a 6 volt positive ground system on gas tractors then went to 12 volt negative ground systems.  ...I'm not sure when the 6 volt systems were phased out, but they were used into the late 1950's.
  • DH1, Gtractor and Cvans have said thanks
#7 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted June 25, 2015 - 10:47 PM
When I first tried to get it going I did the usual, change oil and filter, new plugs, points, condenser, rotor, inside the cap looks good.
I swaped the carb for a know good one and put on a new sediment bowl assembly and flushed out the fuel tank, it was really grungy inside, not sure if it's clean enough. ???
Couldn't get it to run on it's own even by spraying carb cleaner in the carb. It will fire and try to run but when the starter is not turning the engine over it won't stay running.
I hooked up a 12volt battery to the starter both ways, positive ground and negative ground, starter turns same direction both ways.
I was able to get spark at the plugs, hooking the 12volt battery directly up to the coil, negative ground.
I want to hook this up the right way but don't know what way that is. ???
I don't want to spend a lot of $$$ on this as it is not mine and the fellow that owns it doesn't want to put any into it. Just get it going.
I figure to try again this time with a temporary fuel tank hooked up to the carb, check inside the carb make sure it's clean and hook up the ignition so I get spark at the plug.
Just wanted to know when it was made what was it, 6volt, or 12volt, pos or neg ground.
#8 Bill 76 ONLINE
Bill 76
  • 1,930 Thanks
  • 1,190 posts
Posted June 26, 2015 - 12:34 AM
The starter will turn the same way positive or negative ground unless you change the internal wiring on the field coils--sorry I'm no other help.
#9 Rock farmer ONLINE
Rock farmer
  • 1,198 Thanks
  • 1,233 posts
Posted June 26, 2015 - 06:21 AM
It should have left the factory as a six volt positive ground system.
If it were a diesal it would have been twelve volt negitive ground.
But, you should have just hooked up the battery the way it was last installed.
The battery terminals are diferent sizes. Battery cable ends are sized differently to suit.
I'd suggest you check the compression before doing anything else.
Joe
#10 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted June 26, 2015 - 07:12 AM
Joe
Rings may be stuck. Sometimes running them long enough to get HEAT into the rings will loosen the up.
#11 Bud W OFFLINE
Bud W
  • 325 Thanks
  • 302 posts
Posted June 26, 2015 - 09:25 AM
A 6 volt battery will only have 3 cells (fill caps), the 12 volt battery has 6 cells.
#12 Cvans ONLINE
  • 6,648 Thanks
  • 6,128 posts
Posted June 26, 2015 - 09:59 AM
There are two screws that hold the points mounting plate into the bottom of the distributor. If they become loose or corroded the points can't ground properly. Your engine will run erratically or not at all. Check all the screws inside the distributor and make certain they are tight.
Trying turning the engine over when it's dark outside and see if you can find any arcing in the ignition system.
  Be careful around moving parts.
#13 Bill 76 ONLINE
Bill 76
  • 1,930 Thanks
  • 1,190 posts
Posted June 26, 2015 - 03:53 PM
Pop out a head light and see if it's marked 6volt or 12volt ---most are stamped with the voltage---almost all 6volt systems are positive ground.
AS critters said the rings are probably stuck --they should free up after getting some heat in the engine.
after you get it running you may have to flash the regulator to make the charging system work but do that with engine off
#14 Cvans ONLINE
  • 6,648 Thanks
  • 6,128 posts
Posted June 26, 2015 - 09:54 PM
Pull the plugs and squirt some Marvel Mystery Oil in each cylinder. I would let it soak for at least a day.
#15 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,360 posts
Posted June 29, 2015 - 11:03 AM
I was going to suggest some ATF into each cylinder and letting it sit for two or three days to free up the rings if they are stuck.
