cylinder head-paint or not
8 replies to this topic
#1 lrhredjb OFFLINE
lrhredjb
  • 871 Thanks
  • 650 posts
Posted June 24, 2015 - 09:08 PM
I'm of the opinion that cylinder heads will run cooler without paint than with. All air cooled motorcycles with alloy heads are unpainted, Water cooled alloy heads can be painted and cast iron heads should be painted. I plan to bead blast my Kohler head to remove the paint next time I do a head gasket job.
What's your thoughts about this?
  • laurarg3 said thank you
#2 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,978 Thanks
  • 2,475 posts
Posted June 24, 2015 - 09:55 PM
Your tractor, your choice!
Many engines came from the factories with cylinder heads fully, or partially, painted.
The paint possibly helps prevent corrosion of the aluminum head.
  • superaben said thank you
#3 lrhredjb OFFLINE
lrhredjb
  • 871 Thanks
  • 650 posts
Posted June 24, 2015 - 10:25 PM
That's because they have to paint the cast iron to prevent rust and it's easier to just paint everything. Mine tractor even had the rubber fuel line painted.
  • Cvans and HANKG have said thanks
#4 glgrumpy OFFLINE
  • 8,803 Thanks
  • 8,009 posts
Posted June 24, 2015 - 11:01 PM
Many don't have heads or the cylinder fins painted because the tins are on there and paint don't reach. I do the tins over and usually leave the fins bare or rusted as they may be. Keep in mind paint is just for looking pretty long enough to get it sold and look new for awhile.  Even big tractors and GT's never used to get parts painted, mostly near final assemblys and sprayed, many items getting painted that didn't really need it.
  • Alc and superaben have said thanks
#5 HANKG ONLINE
HANKG
  • 6,589 Thanks
  • 3,527 posts
Posted June 25, 2015 - 07:22 AM
I personally like them not painted, if bead blasting the head the contrast of shinny new metal looks great against the painted tins and block
  • Alc and Coventry Plumber have said thanks
#6 Coventry Plumber ONLINE
Coventry Plumber
  • 1,089 Thanks
  • 590 posts
Posted June 25, 2015 - 07:38 AM
I agree with HankG totally . Unpainted
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 25, 2015 - 07:44 AM
No paint.
#8 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted June 25, 2015 - 08:39 AM
To me, it depends on the engine.  I'm inclined to leave a Kohler aluminum heads unpainted since it is prone to running hot, and then paint the rest.  I usually leave aluminum heads unpainted and paint all cast iron heads.  Briggs, Clinton, Wisconsin, and on with cast iron heads have always been painted.
Ben W.
#9 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,449 Thanks
  • 4,570 posts
Posted June 25, 2015 - 10:52 AM
I paint mine, 14hp Kohler, 18hp Briggs X-2, 20 hp Onan. Not had an issue.
