kohler backfire on deceleration
11 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted June 24, 2015 - 06:19 PM
my 12 hp kohler backfires on deceleration . its not terrible but I know that is a symptom of something
I just fired it up after it sat for a while runs good just backfires slightly . I have marvel in the gas .
to rich to lean ? thanks for any suggestions
  • Lmiller3358 said thank you
#2 olcowhand ONLINE
  • 39,716 Thanks
  • 30,984 posts
Posted June 24, 2015 - 06:25 PM
Sounds like lean due to an air leak on the intake manifold or maybe a worn throttle shaft, or simply a dirty carb jet.  Marvel may clear it up.
  • MH81, Lmiller3358, superaben and 2 others have said thanks
#3 propane1 ONLINE
propane1
  • 8,223 Thanks
  • 3,964 posts
Posted June 24, 2015 - 06:35 PM
Lean mixture, set your high speed jet a little rich. Adjust when on full throttle and warmed up. Turn in, lean, until speed slows a little, then turn out, rich, until speed slows a little, then turn to the middle setting. Then adjust a little rich. Put engine on idle for a few seconds, then put to full throttle very quickly. Engine should speed up with out any delay. If it stumbles abit, then set the mixture a little richer, until it's good. If it does not work, you have other troubles. Check setting of points also. Noel.
Edited by propane1, June 24, 2015 - 06:37 PM.
  • Gtractor, MH81, Lmiller3358 and 2 others have said thanks
#4 DH1 ONLINE
DH1
    Electric Tractors
  • 5,136 Thanks
  • 5,521 posts
Posted June 24, 2015 - 07:38 PM
I'd say there is a hole in the muffler/exhaust somewhere, that allows air to get sucked in, mixes with the hot rich fuel mixture on deceleration and ignites causing the backfire.
Fix the exhaust leak and the backfire will disappear.
  • olcowhand, MH81, superaben and 1 other said thanks
#5 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted June 24, 2015 - 10:28 PM
thanks guys !   I am savin this post . lots of good stuff here .  turns out she just wanted some love , let it run for a bit , oiled the governor linkage and she goes up and down sweet now no backfires the marvel probably did it .. its a mystery oil  :thumbs:
  • olcowhand and MH81 have said thanks
#6 Cvans OFFLINE
  • 6,297 Thanks
  • 5,990 posts
Posted June 24, 2015 - 10:39 PM
I think I will have to agree with the above. If there is no oxygen there can be no fire. If it were lean there would be no fuel to burn. Late ignition timing might also lead to this problem.
Hope you will report back on what you found so we can learn from your experience.
  • MH81 and alec have said thanks
#7 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted June 24, 2015 - 11:26 PM
look at post  above  yours  :usa:
  • MH81 and Cvans have said thanks
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,195 Thanks
  • 5,795 posts
Posted June 25, 2015 - 07:47 AM
Just a little late. :poke:
  • alec said thank you
#9 joel christensen OFFLINE
joel christensen
  • 37 Thanks
  • 21 posts
Posted June 29, 2015 - 02:30 PM
Question,  Was it a true backfire or a pop.  My John Deere 140 has a pop when you decellerate quickly and it's kinda annoying, but I wouldn't really call it a KaPow backfire.
#10 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted June 29, 2015 - 02:41 PM
more pop than kapow but its gotten better
#11 Cvans OFFLINE
  • 6,297 Thanks
  • 5,990 posts
Posted June 30, 2015 - 07:50 PM
You might have some carbon build up in the muffler. This can get hot enough to glow and ignite un-burned fuel when you shut the throttle down.
#12 TAHOE OFFLINE
TAHOE
  • 7,748 Thanks
  • 5,583 posts
Posted July 01, 2015 - 07:12 AM
My Sears gets the bad popping/back fire on deceleration if I shut it down quickly, but then my ignition set up is always at advance 25* so it can't catch up if I idle down too quick.
