Kohler Command 12.5 No spark or compression in my cub cadet mower
kohler no spark no compression
3 replies to this topic
#1 RonaldDean OFFLINE
RonaldDean
  • 1 Thanks
  • 1 posts
Posted June 24, 2015 - 06:10 PM
I'm looking for troubleshooting help with my cub cadet mower.  I'm not getting any spark and hardly any compression.
Yesterday, my mower would start, then stall.  It did this twice.  Now it will no longer start at all.  It will spin over but will not start.  I think it's lost compression, because it will spin over faster than normal.  I tried checking compression with my thumb over the spark plug hole.  I felt very little compression doing this.
The spark plug is not firing.  I checked the plug in a different machine and the plug will fire in that machine.  I checked a different spark plug in the mower, but I did not get any fire.
Could it be that the coil has gone bad?  How would I check this to find out?
Also, does anyone know how I would find out if this engine has a compression release?  I do not have any manuals to check this?
Kohler Engine information:
Kohler Command 12.5
Spec number:  1211
Serial Number 1922008244
Here is the information on the coil
Coil number:  02 51
KK 12-584-04
REP 14386-04
        03 069 11
Mower information:
Cub Cadet Model 130232100
Serial 190774
MFG DATE:  F010G
Thanks in advance.
  • laurarg3 said thank you
#2 shorty ONLINE
shorty
  • 5,776 Thanks
  • 5,392 posts
Posted June 24, 2015 - 07:00 PM
Welcome to GTtalk!
#3 boyscout862 ONLINE
  • 13,449 Thanks
  • 9,394 posts
Posted June 24, 2015 - 09:00 PM
Welcome to GTT. You can find the Kohler Manuals in our Manuals Section. You are allowed 3 free downloads per day.
The loss of compression can be from several problems but attack the easiest one first. The exhaust valves sometimes rust and get stuck in their guides. Try pulling the plug, spraying some WD 40 through the sparkplug hole and then using a bent wire to feel if the valves are moving while you turn the flywheel by hand. Check that the piston is moving too. If the exhaust valve is not moving, Move the piston to top of the cylinder and wait for the WD to let the valve slide closed. Repeat this until the valve frees up. Follow the troubleshooting guide for finding the ignition problem. Good Luck, rick
#4 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,047 Thanks
  • 5,989 posts
Posted June 24, 2015 - 09:45 PM
Welcome aboard!  The boyscout gave great advice for you..  Easy turning is usually a busted rod or busted cam or stuck valves..  What tractor is it in?
Also tagged with one or more of these keywords: kohler, no spark, no compression
