Onan B48M-GA help
15 replies to this topic
#1 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,050 posts
Posted June 24, 2015 - 05:25 PM
I have an onan I am having problems with. It was running great. Went to lunch and came back and it didn't want to start. It finally started but won't run past idle. I cleaned the carb and same thing. I have great compression 115lbs and great spark. What is going on. I notice that my dip stick is loose and can move around. I was thinking condenser?
#2 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,050 posts
Posted June 28, 2015 - 08:59 AM
Cleaned the carb, sonic cleaned and super cleaned I mean It's clean. I bought a complete carb kit, and replaced all the fuel lines and filter. Changed gas just in case and still crap.it spits a little gas out the carb. What am I missing?
#3 MH81 OFFLINE
Posted June 28, 2015 - 09:17 AM
Won't go above idle
Sounds like a port in the carb to me. Getting idle fuel, but main nozzle not allowing fuel.
Did you run something thru each passage?
Have you sprayed the seams and intake gasket with carb cleaner? (If bad seal or gasket, you'll hear a change in the engine.
Does choke on allow you to accelerate?
"Spits gas back out thru carb"
I think all mine do this.
Get something VERY insulated and pull one plug wire at a time while its running.
Also, my one Onan decided to run bad... Very bad... Ended up being poor ground to the points. Loosened the Allen screws and cleaned up. One star washer later, all was well.
#4 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,050 posts
Posted June 28, 2015 - 09:57 AM
I can't even get it to run now. When I can I will try to check the intake. I did not run anything threw the main jet, I soaked it in lacquer thinner for 2 days and sonic cleaned it. But I will try that next.
#5 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,050 posts
Posted June 28, 2015 - 10:15 AM
No change with unlit propane. If I disconnect each wire it kills it either way.
#6 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,050 posts
Posted June 28, 2015 - 10:52 AM
Cleaned the points. I am getting spark to the plugs but not the brilliant hard spark.
#7 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,050 posts
Posted June 28, 2015 - 11:28 AM
Everything is disconnected from the coil, I put my ohm meter as low as it will go and I am reading 5.9 to 9 and it wont stay in one spot. With all my symptoms does a bad coil make the most since?
#8 MH81 OFFLINE
Posted June 28, 2015 - 02:40 PM
I don't know what the ohms should be. I can check my 19.9 in a few minutes.
#9 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,050 posts
Posted June 28, 2015 - 02:43 PM
I think it's my coil. It has a small crack on top and has a 5.6 reading if I tested correctly
#10 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,050 posts
Posted June 28, 2015 - 02:45 PM
Pictures
#11 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,050 posts
Posted June 28, 2015 - 02:46 PM
My readings variet but nothing lower the 5.3. So million dollar question can this be my problem?
#12 MH81 OFFLINE
Posted June 28, 2015 - 02:54 PM
It could be a reason for it to act up.
If you give it some carb cleaner or a little fuel... Will it fire?
#13 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,050 posts
Posted June 28, 2015 - 03:03 PM
It will fire and run very roughly.
#14 MH81 OFFLINE
Posted June 29, 2015 - 06:27 AM
I would finish the carb cleaning (ports) and then condenser, then coil
The coil will be the expensive part.
#15 Dayton_King ONLINE
Dayton_King
  • 1,256 Thanks
  • 1,050 posts
Posted June 29, 2015 - 11:01 AM
Ports are clean, I went over them again. This is probably the cleanest carb I have done. I put a nos brand new carb on last night and same thing. I will try the condenser
