Another loader tractor on the trailer.
25 replies to this topic
#16 Sdhdcouple OFFLINE
Sdhdcouple
  • 147 Thanks
  • 153 posts
Posted July 02, 2015 - 06:08 PM
ya he had that on the farmers market on the 22nd also, I called him about shortly after the show was over at 11am. he said the tractor was sold. someone was on there way to come get it. told him if they back out to call me I would buy it. left him my number. 2 days later he had it on the farmers market again. glad someone from here got it.
  • Cvans and Rock farmer have said thanks
#17 Cvans ONLINE
  • 7,278 Thanks
  • 6,369 posts
Posted July 07, 2015 - 09:30 PM
Had some time to work on the 1920 today and it seems to start and run fine. No smoke and speeds up rapidly when the throttle is advanced. The low speed jet or mixture is going to need some attention as it get's a little rough if idled down real low. The noise he heard is a bit of a mystery. The two spot welds that secure the base for the air filter stud were broken loose and everything was bouncing around. I don't know if that is what he heard or not. I have not engaged the PTO yet so something might turn up there.
  • MH81, KennyP and Talntedmrgreen have said thanks
#18 Cvans ONLINE
  • 7,278 Thanks
  • 6,369 posts
Posted July 17, 2015 - 09:44 PM
  Had the tractor out today for the first time and can't for the life of me find anything wrong with it. It will lift far more than the Bolens will and the loader is faster by quite a bit. There does seem to be more play in the steering than should be and I will have to research that. There is no smoke or unusual noises from the engine that I can find. The oil pressure light goes out shortly after the engine is turning over. The Carburetor will need a kit as it wants to lean out once in a while. The fuel pump is working fine and filled the carburetor shortly after tuning the key on.
  The front tires are going to need replacing and they both are showing their age and are leaking. I don't find any leaks in the hydraulics and the front PTO seems to work fine. I would from observation say that this Simplicity loader is quite a bit beefier than the Johnson workhorse on the Bolens.
#19 Talntedmrgreen OFFLINE
  • 3,285 Thanks
  • 2,314 posts
Posted July 18, 2015 - 05:39 AM
Great feedback Chris!
These are notorious for having the keyways wallow out on the LH spindle. I have had a few where folks just weld the steering arm to the spindle! If that is NOT your cause for loose steering, I would still inspect it closely and keep an eye on it. Its so easy to wreck with the strength of that PS cylinder and a load in the bucket.
I was overjoyed with the loader I had...same one but on an early Legacy. All the capacity you would want for a tractor that size.
  • Cvans said thank you
#20 Cvans ONLINE
  • 7,278 Thanks
  • 6,369 posts
Posted July 18, 2015 - 10:27 AM
Thanks for the information. This loader can pick up a full bucket of pea gravel like nothing. Pretty amazing.
I will have to check the spindles when I can and let you know what I find out.
Thanks again.
#21 Cvans ONLINE
  • 7,278 Thanks
  • 6,369 posts
Posted August 28, 2015 - 10:19 AM
Had time to look at the steering yesterday and Talntedmrgreen was right on with his advise. The key way on the left spindle is loose. If the key way itself is worn I will stick the spindle in the milling machine and mill another key way into it and enlarge the first one so there are two holding it.
Thanks for having me check the spindle!  :thumbs:
  • olcowhand and Talntedmrgreen have said thanks
#22 Talntedmrgreen OFFLINE
  • 3,285 Thanks
  • 2,314 posts
Posted August 28, 2015 - 08:09 PM
Good to hear you have the tool to make it right. I never understood how a heavy tractor like that, with power steering and large front attachments, would have a single key. Even the Sovereigns had 2 keys.
Edited by Talntedmrgreen, August 28, 2015 - 08:10 PM.
#23 UncleWillie OFFLINE
  • 16,251 Thanks
  • 8,969 posts
Posted August 28, 2015 - 08:53 PM
Nice deal. I hate you.
#24 Cat385B OFFLINE
    HAZMAT CAT
  • 14,369 Thanks
  • 10,138 posts
Posted June 07, 2016 - 09:54 PM
There has been a disturbance in the force. You didn't sell this tractor, did you?
:biting_nails:
#25 Cvans ONLINE
  • 7,278 Thanks
  • 6,369 posts
Posted June 07, 2016 - 10:47 PM
Yes. When we visited you didn't think it would workout for you and I hadn't heard anything different. Did I goof?  :oh_shucks:
If it makes any difference the lady that bought it was very nice and liked it a lot.
Edited by Cvans, June 07, 2016 - 10:49 PM.
#26 Cat385B OFFLINE
    HAZMAT CAT
  • 14,369 Thanks
  • 10,138 posts
Posted June 08, 2016 - 07:32 PM
I'm glad it went to a good home.
This is the latest one I have my eye on:
