JD 216 SECONDARY BELT IDLER spring
spring
5 replies to this topic
#1 houndog OFFLINE
houndog
  • 6 Thanks
  • 17 posts
Posted June 22, 2015 - 09:45 PM
My secondary idler pull went bad, and the tension spring jumped off and I cant figure out where it hooks to. I known where it hooks to at the idler arm ,but not at the other end..thx jeff if anybody can help
  • larisaPn and laurarg3 have said thanks
#2 Alc ONLINE
  • 7,131 Thanks
  • 7,533 posts
Posted June 23, 2015 - 05:32 AM
houndog welcome to GTTalk !!  Can't help you but I'm sure there are members here that will be able to answer your question
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 23, 2015 - 07:03 AM
:welcometogttalk:
#4 hdg4400 ONLINE
hdg4400
  • 286 Thanks
  • 352 posts
Posted June 23, 2015 - 09:28 AM
houndog:
I'm probably showing my ignorance here (don't know much about the 216), but are we talking about a belt on the tractor, or on the mower deck?
If it's the mower deck, I have the 46-inch Mid Mount Rotary Mower Operator's Manual. It shows some diagrams of the belt routing on the deck, and when attaching it to the tractor. Let me know if you would like more info.
Harlan
#5 lyall ONLINE
lyall
  • 2,180 Thanks
  • 1,577 posts
Posted June 23, 2015 - 09:47 PM
There is a hole that the spring hooks to.  It is above the variator spring.
I hope you can see the spring.  I put a piece on white tape on the spring.
Now I wish I had painted the spring yellow, it would have been better to see.
It is above the rod for the parking brake, close to the two bolts for the parking brake rod.  It is hard to find the hole for the spring.
You will have to fill for it.
hope this help a little
Have fun and good luck
  • KennyP and houndog have said thanks
#6 houndog OFFLINE
houndog
  • 6 Thanks
  • 17 posts
Posted July 03, 2015 - 01:29 PM
thank you so much Lyall!!!!
Also tagged with one or more of these keywords: spring
