F525 reverse
9 replies to this topic
#1 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted June 22, 2015 - 12:01 PM
The f525 is super slow in reverse so I bought a pedal off eBay that fits in place of the small reverse pedal that is taller and should give me more range. Seems like when I put it on it moves even slower than did before. Any body ever get more speed out of a f525 in reverse and if so how did you do it?
  • larisaPn said thank you
#2 grnspot110 ONLINE
grnspot110
  • 4,321 Thanks
  • 2,696 posts
Posted June 22, 2015 - 05:06 PM
Hook your toe under the forward pedal & lift it!
#3 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted June 22, 2015 - 06:44 PM
Yeah I know but I got a longer pedal that should do the same thing but it doesn't just wondering if anybody has done it by replacing the original reverse pedal with an aftermarket made for that purpose
Edited by 1964Deere, June 22, 2015 - 06:45 PM.
#4 chieffan ONLINE
  • 11,299 Thanks
  • 7,090 posts
Posted June 22, 2015 - 07:37 PM
I have an F525 and have not had any problem yet.  Could it be a linkage wear problem or adjustment?
#5 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted June 22, 2015 - 08:07 PM
I just think the original speed for reverse is super slow
#6 Justin2655 OFFLINE
Justin2655
  • 211 Thanks
  • 151 posts
Posted June 22, 2015 - 08:19 PM
the speed in reverse is slow but, we have a f525 ran great, no trans issue, then the one time we went to back up, it would barely back up then it got to the point where it wouldnt hardly back up at all, you had to push it backwards, ended up finding out that the cable that controls your foot control, was warn out and would just shove the cable side ways, we ended up purchasing a used one for 50 or 60 bucks, a new one is around $120 i believe!
  • Alc and 1964Deere have said thanks
#7 hdg4400 OFFLINE
hdg4400
  • 294 Thanks
  • 357 posts
Posted June 23, 2015 - 09:13 AM
1964Deere:
I found some specifications from John Deere for the 525 that say the speed in reverse is 0 - 2.5 MPH, and forward is 0 - 5.0 MPH. Seems a little slow, my 318 Operator's Manual says reverse is 0 - 3.5 MPH and forward is 0 - 7.5 MPH.
Harlan
#8 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted June 29, 2015 - 06:42 PM
Justin... Exactly what it is. Thanks
  • Justin2655 said thank you
#9 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted July 21, 2015 - 10:19 PM
Having problems getting the new push pull cable set. Does anyone know the preliminary settings and how each threaded adjustment will effect the hydrostat control
#10 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted July 22, 2015 - 08:48 PM
Went to JD this am and found out. The general specs and got it set right tonight
  • olcowhand said thank you
