LGT 145 motor mounts
6 replies to this topic
#1 Jagman OFFLINE
Jagman
  • 25 Thanks
  • 45 posts
Posted June 22, 2015 - 11:27 AM
I'm in the process of rebuilding my 14HP Kohler on the old LGT145, and discovered that the original motor mounts (engine isolators) must be shot because the engine support brackets have worn away the frame tubes. The part number 359364 shows up in a search but cost $32 each, more than I am willing to spend. What would be a good fix, washer shims under the brackets at each mount?
#2 boyscout862 ONLINE
  • 12,831 Thanks
  • 9,158 posts
Posted June 22, 2015 - 12:18 PM
I've used fender washers with a piece of rubber inbetween. Years ago I got some of the inner rubber rings on old 20" split rims. Using a hole saw, I get nice 3/8" cushions to put between the washers. Do that above and below the mount and it should work similar to original. Be sure to use lock nuts and don't over tighten the bolts. Good Luck, Rick
  • Jagman said thank you
#3 KennyP ONLINE
  • 38,242 Thanks
  • 45,869 posts
Posted June 22, 2015 - 02:09 PM
I used these, I think it was the 90 lb. flush. These folks have some too!
  • boyscout862, TomLGT195 and Jagman have said thanks
#4 Jagman OFFLINE
Jagman
  • 25 Thanks
  • 45 posts
Posted June 22, 2015 - 04:10 PM
Two great suggestions - thanks. Why do I always forget that McMaster-Carr has just about everything on earth! Now I just have to decide on which way to go.
  • KennyP and TomLGT195 have said thanks
#5 Jagman OFFLINE
Jagman
  • 25 Thanks
  • 45 posts
Posted July 18, 2015 - 08:23 AM
As a start, I'm trying two fender washers at each mount between the mount and the support bracket to get the engine up off the chassis. Time will tell if this does the trick or if the rubber in the mounts just sags down farther.
#6 KennyP ONLINE
  • 38,242 Thanks
  • 45,869 posts
Posted July 18, 2015 - 10:25 AM
Good luck!
#7 txdieseldog OFFLINE
txdieseldog
  • 56 Thanks
  • 52 posts
Posted July 18, 2015 - 11:10 PM
There is also this guy on evilbay. I saw several sizes on first page for $12.50.
http://stores.ebay.c...=p2047675.l2563
