Block cleaning
13 replies to this topic
#1 txdieseldog OFFLINE
txdieseldog
  • 56 Thanks
  • 52 posts
Posted June 21, 2015 - 11:16 PM
OK guys, need some input. I finally got started on the rebuild of my 20 hp B&S V-twin for my Jac. I sprayed degreaser and power washed it before dis-assembly, but it has a weird yellowy finish in spots that looks like left over clear coat on the block. I'd like it squeeky clean but I'm not sure I want to go the bead blast route. Any ideas? Anything you guys have seen that will beautify the aluminum without harsh side effects? Thanks in advance.
Barry
  • Chopperhed and laurarg3 have said thanks
#2 Bill 76 ONLINE
Bill 76
  • 2,015 Thanks
  • 1,208 posts
Posted June 21, 2015 - 11:34 PM
DON"T bead or sand blast it , that stuff will get into places and you will never get it out----Walnut shells is supposed to work good for blasting cuz anything that can't be cleaned out won't hurt anything same goes for soda blasting just rinse it off with water.Gunk brand carb cleaner dip cans works great but for a block you would need a 5 gallon bucket and it pricey.
  • Chopperhed said thank you
#3 chieffan ONLINE
  • 11,775 Thanks
  • 7,282 posts
Posted June 21, 2015 - 11:45 PM
Try some cheap oven cleaner.  I use it on most of the items with grease/dirt/grime/?? I want removed including paint.  Learned this from a friend that restores and paints old tractors.  Spray it on, let it set for 15 - 20 min and power wash it off.  Heavy areas may need a couple try's and caked stuff more.  Wear eye protection as this stuff is caustic.
  • Chopperhed, Bill 76 and Marty'70 have said thanks
#4 boyscout862 ONLINE
  • 13,691 Thanks
  • 9,475 posts
Posted June 22, 2015 - 02:47 AM
I would not use walnut shell pieces on an engine. During WWII the OSS used ground up walnut shells to sabotage Nazi engines. A small rubber package of powdered walnut shells would be dropped in the engine oil fill opening. The rubber dissolved and released the powder. It would cause the engine to sieze in a short time. Good Luck, Rick
  • Chopperhed and Bill 76 have said thanks
#5 Alc OFFLINE
  • 7,351 Thanks
  • 7,634 posts
Posted June 22, 2015 - 05:38 AM
I'm always afraid I would get abrasives in the block and they wouldn't come out during the final cleaning . Since your mostly concerned with the external , could you put the head , old gaskets on , duct tape/ seal the other openings and then glass bead the outside ?
  • boyscout862 and Chopperhed have said thanks
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 22, 2015 - 07:48 AM
Still will get into places that you didn't know existed.
  • Alc, boyscout862, Chopperhed and 1 other said thanks
#7 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,672 Thanks
  • 4,647 posts
Posted June 22, 2015 - 01:54 PM
Scotch brite pads and simple green here. takes some elbow grease and works fine.
#8 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 878 Thanks
  • 724 posts
Posted June 22, 2015 - 03:45 PM
Love the oven cleaner too! And a big ditto on using good PPE. That stuff burns bare skin.
  • boyscout862, Chopperhed and Bill 76 have said thanks
#9 txdieseldog OFFLINE
txdieseldog
  • 56 Thanks
  • 52 posts
Posted June 23, 2015 - 10:38 PM
I have heard from another forum that "Purple Power" from walmart or dollar general works well. I soaked half in 3 gallons and flipped it tonight. It's looking pretty good. Thanks for all the input. I guess I was just looking for that one quick miracle, but I should have known better!!! :wallbanging:  It still takes some effort with these ol' rigs. Aint no such thing as the easy way out!! :(
  • Alc and Chopperhed have said thanks
#10 KennyP ONLINE
  • 41,472 Thanks
  • 47,403 posts
Posted June 24, 2015 - 04:39 AM
Purple Power is pretty good stuff. Use it often!
#11 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted June 24, 2015 - 05:15 AM
Take the block to the local tranny shop and ask him if he can put it in his washing machine! It will come out spotless and wont hurt the aluminium. Or put it in your own dish washer( make sure the wife is no where to had or she will surely kill you) a little cascade and it will look like new.
#12 txdieseldog OFFLINE
txdieseldog
  • 56 Thanks
  • 52 posts
Posted June 24, 2015 - 11:26 PM
The Purple Power got it looking pretty good with just an overnight soak and a power washer. I'll take some pics tomorrow and post my results.
#13 Jahcure OFFLINE
Jahcure
  • 2 posts
Posted June 25, 2015 - 03:50 PM
Put in dish washer and take before and after pics 😀
#14 jabelman ONLINE
jabelman
  • 2,329 Thanks
  • 1,645 posts
Posted June 25, 2015 - 07:54 PM
Yeah I was actually surprised by that purple spray. It did a decent job on a frame. I saw it at Walmart a few weeks ago gave it a try.
