New Tractor In The Barn Sears FF18
38 replies to this topic
#16 Alc OFFLINE
  • 6,741 Thanks
  • 7,395 posts
Posted July 06, 2015 - 07:36 AM
Is there a drain on the bottom or just the red hose ?
#17 KennyP OFFLINE
  • 37,425 Thanks
  • 45,461 posts
Posted July 06, 2015 - 08:18 AM
There is a drain plug at the bottom. Then a fill port that Sears added since the frame covers it. Then the vent that the red hose is attached to.
#18 Alc OFFLINE
  • 6,741 Thanks
  • 7,395 posts
Posted July 06, 2015 - 10:35 AM
Kenny is this what your talking about in your other thread about the Ford winning ?  This holds extra oil ?
#19 KennyP OFFLINE
  • 37,425 Thanks
  • 45,461 posts
Posted July 06, 2015 - 12:08 PM
Since the hose hooks on a fitting and curls out of the frame, it allows more fluid in the tranny. The FF you fill till fluid can be seen in the hose.
#20 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,790 Thanks
  • 2,755 posts
Posted July 07, 2015 - 02:29 PM
I cleaned up the brass screen on the vent today, and I got the old tranny fluid drained out.  Picked up some of the paint you mentioned, and I ordered a set  of FF/18 decals.  That hammered silver does match up good.  Thanks Kenny!
Edited by Delmar, July 07, 2015 - 02:30 PM.
#21 KennyP OFFLINE
  • 37,425 Thanks
  • 45,461 posts
Posted July 07, 2015 - 02:33 PM
Glad to help you out! Maybe I can get mine painted one of these days! Just seem to use it too much!
  • jimbobbillyray said thank you
#22 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,790 Thanks
  • 2,755 posts
Posted July 08, 2015 - 03:36 PM
I got some of it painted yesterday, rain all day today slowed things down a bit.  I did get the new filter and tranny fluid in it.  cleaning the vent and new fluid and filter seem to speed it up a bit and give it better response.   I put the front end up against a tree in the back yard to see how the rear-end/hydro were going to be....I did not know that this tractor has posi-trac too!  Awesome!
#23 KennyP OFFLINE
  • 37,425 Thanks
  • 45,461 posts
Posted July 08, 2015 - 04:17 PM
If you had AG's on there, you'd have dug deep holes! That's the limited slip in the Peerless 2500 working.
#24 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,790 Thanks
  • 2,755 posts
Posted July 10, 2015 - 09:15 AM
I got the ag tires on the rims yesterday.  I used some goo gone to remove the sticky stuff left behind by the massey 1855 stickers, and then I sanded everything with water and wet/dry 100 grit paper.  After that  I got the first coat of paint on the hood and fender.  This morning I sanded them out with some 400 grit wet/dry paper, and then applied the 2nd coat of paint.
I'm glad to see it ain't red anymore!
Edited by Delmar, July 10, 2015 - 09:23 AM.
  • olcowhand and Cat385B have said thanks
#25 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,790 Thanks
  • 2,755 posts
Posted July 11, 2015 - 06:03 PM
Well, I put the Sears back together today.  It turned out pretty good.  I liked the red paint that was on it when I found it, but it looks better like this I think.   Got all the kids out for a photo shoot this morning while I was at it.
Edited by Delmar, July 11, 2015 - 06:46 PM.
  • coldone and KennyP have said thanks
#26 KennyP OFFLINE
  • 37,425 Thanks
  • 45,461 posts
Posted July 11, 2015 - 06:31 PM
Looks good! I think the kids enjoyed being out!
#27 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,790 Thanks
  • 2,755 posts
Posted July 24, 2015 - 05:23 PM
Guess what came in the mail today?  Decals!   I sure wish they had also had the tail light decals and the orange stripe on the hood decals...
#28 KennyP OFFLINE
  • 37,425 Thanks
  • 45,461 posts
Posted July 24, 2015 - 05:27 PM
I usually paint the orange stripe!
#29 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,790 Thanks
  • 2,755 posts
Posted July 24, 2015 - 05:32 PM
That is what I will probably do.  I still have the tail light decals on the  parts tractor, I can use those for a pattern.  I just need to find some red reflective 4 inch wide tape, I guess.....
#30 KennyP OFFLINE
  • 37,425 Thanks
  • 45,461 posts
Posted July 24, 2015 - 05:35 PM
Here's some solid Red tape!
