ST/12 fuel problems?
7 replies to this topic
#1 rohrspencer OFFLINE
rohrspencer
  • 37 Thanks
  • 24 posts
Posted June 20, 2015 - 09:10 AM
ok so I bought a ST/12 the other day and the man said the fuel pump was the problem, so I went to my parts dealer he said he had one couldnt find it so I said no big deal. Got back to the shop took fuel pump off and just got a little gas tank and ran a fuelline to the carb from it and it will not fire does anyone know what is wrong.
THANKS
  • chieffan and laurarg3 have said thanks
#2 TAHOE ONLINE
TAHOE
  • 8,309 Thanks
  • 5,803 posts
Posted June 20, 2015 - 09:14 AM
This is probably a Tecumseh?
Do you have fire? Pull and ground plug on head to check for fire or maybe a little shot of starter fluid to see if it will fire.
If not fire, then could be a few things, but most likely a bad SSI module
If you do have spark, then it could be a dirty/clogged carb.
#3 dthomp17 OFFLINE
dthomp17
  • 605 Thanks
  • 482 posts
Posted June 20, 2015 - 09:55 AM
I agree
#4 rohrspencer OFFLINE
rohrspencer
  • 37 Thanks
  • 24 posts
Posted June 20, 2015 - 11:06 AM
I tried fluid and nothing and yes I have great spark. but on the fuel pump another line ran to it from the engine what do I do with that line?
#5 TAHOE ONLINE
TAHOE
  • 8,309 Thanks
  • 5,803 posts
Posted June 20, 2015 - 02:36 PM
That would be the vacuum line that worked the pump. You can plug or cap it.
So it won't fire on fluid even though you have spark? Either it's too weak of spark or very low compression.
#6 glgrumpy OFFLINE
  • 8,815 Thanks
  • 8,014 posts
Posted June 20, 2015 - 11:10 PM
Get one of those generic plastic pumps, most say for Briggs and Stratton with the three hose connectors and mount it on tractor or engine shroud to get it working. IF you have spark, yet won't fire on start fluid, has to be a carb or intake problem would think. Do you have choke open all the way when  you spray it? Start fluid you don't need choke closed, and it is in way of the spray going in sometimes. I'm assuming you have air cleaner off then too? Kits are still available for those carbs, I'ld look at that first.
#7 rohrspencer OFFLINE
rohrspencer
  • 37 Thanks
  • 24 posts
Posted June 21, 2015 - 05:57 PM
Thank you guys plugged vacuum line and runs great now!!!
  • TAHOE said thank you
#8 glgrumpy OFFLINE
  • 8,815 Thanks
  • 8,014 posts
Posted June 22, 2015 - 01:07 PM
HA!  Don't you love it when you overlook the obvious stuff so easy and try all the hard stuff first?? :D  Glad to hear it is a runner again, now go out and get Seat-Time!
