Open Steering Gears
11 replies to this topic
#1 Gabriel OFFLINE
Gabriel
  • 1,440 Thanks
  • 1,858 posts
Posted June 18, 2015 - 10:51 PM
I was wondering, should open (open to dust, dirt, grass, moisture, etc.) steering gears on lawn or garden tractors be lubricated or left dry? Thanks.
  • holdenboy1960 and laurarg3 have said thanks
#2 glgrumpy OFFLINE
  • 6,809 Thanks
  • 6,603 posts
Posted June 19, 2015 - 03:00 AM
Wheelhorse used those, down low in frame and had zerks on them and you could also put some on by hand over the arc gear. They did get some stiff and a little dirty, but most grass stayed out of area. SO, guess I would go with grease. Might need to make a little tin cover on it if place available to help keep more clean?
  • boyscout862, Gabriel and holdenboy1960 have said thanks
#3 48willys OFFLINE
48willys
  • 147 Thanks
  • 83 posts
Posted June 19, 2015 - 06:34 AM
They make a spray  Open gear & chain lube , I think its made so dirt will not stick to it.
  • Gabriel and holdenboy1960 have said thanks
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,169 Thanks
  • 5,762 posts
Posted June 19, 2015 - 07:24 AM
I always keep them greased.
#5 MH81 ONLINE
  • 28,003 Thanks
  • 28,948 posts
Posted June 19, 2015 - 07:37 AM
I tend to spray lube (washes out old dirt) unless someone has already greased, then I keep greasing.
#6 Gabriel OFFLINE
Gabriel
  • 1,440 Thanks
  • 1,858 posts
Posted June 19, 2015 - 09:44 AM
If they've been previously lubricated and have dirt mixed in with the old lubricant, should I clean them before re-lubrication, or is that not important?
Edited by Gabriel, June 19, 2015 - 09:45 AM.
#7 MH81 ONLINE
  • 28,003 Thanks
  • 28,948 posts
Posted June 19, 2015 - 10:58 AM
I would, it doesn't take long.
#8 Gabriel OFFLINE
Gabriel
  • 1,440 Thanks
  • 1,858 posts
Posted June 19, 2015 - 11:24 PM
What would be the best way to clean them? On one of our lawn tractors for example, the steering gears are behind the engine on top of the frame and are not very easy to reach to clean them throughly.
#9 MH81 ONLINE
  • 28,003 Thanks
  • 28,948 posts
Posted June 20, 2015 - 06:10 AM
Most aerosols would or could damage paint or plastic, soak It with simple green and spray it off?
Maybe a slimy mess when done, IDK
If it doesn't sound gritty and is a bear to get to, maybe just leave it alone and regrease ?
#10 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted June 20, 2015 - 08:35 AM
I would say they need some kind of lube. My dad has a nice Craftsman lawn mower and last summer I helped him Chang the rack and pinion in it. The rack was aluminum and it had stripped the teeth. He has a small lawn and does not abuse equipment.
Some kind of dry lube would be best, since grit and dust will get into them.
#11 holdenboy1960 OFFLINE
holdenboy1960
  • 1,472 Thanks
  • 819 posts
Posted June 24, 2015 - 07:31 AM
my Rover & greenfield's have open steer cogs on them , i only use high temp grease on them all they need , remember to lube the steer shaft as well under the steering  wheel
 a lot of the Australian stuff had open gear sets for the steering on the riders & gt's , all the old stuff
 but all of mine are steel gears ,  none are alloy at all
Shane
Edited by holdenboy1960, June 24, 2015 - 07:33 AM.
  • Gabriel said thank you
#12 holdenboy1960 OFFLINE
holdenboy1960
  • 1,472 Thanks
  • 819 posts
Posted June 24, 2015 - 07:37 AM
degreaser and hose or pressure washer
Shane
