Stiff, stick throttle and choke cables
6 replies to this topic
#1 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted June 18, 2015 - 12:33 PM
Last winter I had a lot of problems with throttle and choke cables freezing. Now they are stiff hard to operate. What can I do to loosen them up and prevent them from freezing next winter?
Thanks. Jim
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted June 18, 2015 - 12:52 PM
Once the insides get crusty  there's not much you can do for them......
Are yours still originals?
#3 fogler12538 OFFLINE
fogler12538
  • 284 Thanks
  • 170 posts
Posted June 18, 2015 - 01:00 PM
Yes
#4 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted June 18, 2015 - 01:18 PM
If they are the up and down lever style you can replace just the wire's saving your old control heads.
The new wire has a protective oil coating on it
#5 Doxey OFFLINE
Doxey
  • 202 Thanks
  • 148 posts
Posted June 18, 2015 - 02:01 PM
I've had that problem before too. I just sprayed a penetrating oil on the outside. May have to let it soak for awhile. Then work back and forth until free. Worked for me. I'm talking about the spring looking type.
Edited by Doxey, June 18, 2015 - 02:03 PM.
#6 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted June 18, 2015 - 10:52 PM
That's what I normally do.
#7 lrhredjb ONLINE
lrhredjb
  • 698 Thanks
  • 570 posts
Posted June 20, 2015 - 07:49 AM
I had a real stiff throttle cable on my CC106 that I fixed by barely dribbling Marvel mystery oil down the solid wire center so it would creep in between the outer casing and inner cable. You may have to disconnect the cable and hold the end vertical to do this.
Another trick from my motorcycling days, get a good quality smaller balloon and fill part way with the lubricant of choice. Insert the end of the cable in the balloon and seal to cable with a zip tie or whatever and then gently squeeze the balloon until you see the lubricant coming out from the other end of the cable. It can be kind of messy. :D
