Pk 1614 and agri fab tiller
5 replies to this topic
#1 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted June 18, 2015 - 11:54 AM
I have a pk 1614 with 3 point hitch and a motorized agi fab tow behind tiller. I would like to use the tiller with the 3 point hitch. Any ideas for a adapter for the hitch? Thanks a lot.
  • laurarg3 said thank you
#2 EconChuck OFFLINE
EconChuck
  • 251 Thanks
  • 288 posts
Posted June 18, 2015 - 02:44 PM
Hi,
My suggestion would be to use one of the 3 pt A frame parts and mount the tiller to that.
The Cat 0 A frames can be had used for $50-100.
I may not be using the proper term for the part, but it has a drawbar  that connects the 2 lift links and welded uprights that
go vertical and the upper link attaches there.
Chuck
  • jjln50 said thank you
#3 KennyP ONLINE
  • 29,512 Thanks
  • 40,495 posts
Posted June 18, 2015 - 04:11 PM
Hi,
Chuck
I think this is what he is talking about.
  • Alc and jjln50 have said thanks
#4 MNGB ONLINE
MNGB
  • 1,090 Thanks
  • 881 posts
Posted June 20, 2015 - 05:57 PM
Hi jjin50, you could use the pull behind and use the 3 pt to rase it at the end of the run turn and then lower the 3 pt to engage the tiller.
#5 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted October 31, 2015 - 06:56 PM
Just a update on tiller. Brought a 30 dollar electric actuator and mounted it to the lift handle, works great. I was afraid the tongue would bend lifting with the 3 point hitch.
  • Alc and MNGB have said thanks
#6 David Brown OFFLINE
David Brown
  • 4,403 Thanks
  • 2,385 posts
Posted October 31, 2015 - 08:00 PM
Do you have dual trannies on your PK?  You may need them unless your soil is very soft.
  • MNGB said thank you
