J D 455--engine & mower quit after short use time and battery low or dead
j d 455
8 replies to this topic
#1 stogey#1 OFFLINE
stogey#1
  • 1 Thanks
  • 2 posts
Posted June 18, 2015 - 11:28 AM
After mowing 3 hrs, my wife shut off our JD 455 then it would not start and battery was very low. boosted batt and got running agin.
checked alternator when running--output 12.99 volts. after about 15 minutes mowing---engine stops dead. try to start--no go. checked batt voltage 9.75 then rapidly increasing up to normal range.
boosted batt again to start---running and mowing then shut down again---same results.
Questions :  battery seems ok---alternator seems ok  possible bad cell in battery ???
any suggestions would be greatly appreciated. I would like to try and fix myself if possible.
Thank you, all for any input or suggestions. Take Care.
Larry
  • Alberta Bolens said thank you
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted June 18, 2015 - 12:57 PM
:welcometogttalk: 12.99 is NOT charging. That's battery voltage.
  • Marty'70 and stogey#1 have said thanks
#3 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 862 Thanks
  • 719 posts
Posted June 18, 2015 - 01:10 PM
:welcometogttalk: 12.99 is NOT charginzg. That's battery voltage.
Ditto. 12.99 is just above battery voltage. Check regulator or alternator.
#4 stogey#1 OFFLINE
stogey#1
  • 1 Thanks
  • 2 posts
Posted June 18, 2015 - 02:14 PM
Thank you Critters and Marty !!!!
That's what I thought also but I did not know what the charging number should be-----few years back a repairman replaced the original JD alternator with a $ 115.00 Chinese model. Only lasted maybe 4 years at 8 hours per week cutting.
Guess I will pull the old J D one out of storage and see if I can get bearings for it and put it back in. Even though the original was rattling like a snake, it was still working. I'll have to look for a rebuild kit for it.  Tractor is a '96 model and only has 1460 hrs.
Thank you again gentlemen for your help and advice. Take Care
Stogey # 1
#5 Bill 76 OFFLINE
Bill 76
  • 1,938 Thanks
  • 1,192 posts
Posted June 18, 2015 - 03:30 PM
What marty and critters said 12.9 is just battery voltage---charging voltage is around 14.5 volts
  • stogey#1 said thank you
#6 DennyIN OFFLINE
DennyIN
  • 343 Thanks
  • 207 posts
Posted June 18, 2015 - 05:22 PM
Probably a dumb question, but the 455 is a diesel, I can understand why the mower would quit with low battery voltage, but why would the diesel engine quit?
#7 WHdbJD ONLINE
WHdbJD
  • 686 Thanks
  • 516 posts
Posted June 18, 2015 - 06:34 PM
I'm not a diesel mechanic, but I'm going to guess that the voltage was not high enough to hold the fuel
selonoid open?
  • WNYTractorTinkerer and DennyIN have said thanks
#8 olcowhand OFFLINE
  • 41,220 Thanks
  • 31,437 posts
Posted June 18, 2015 - 07:29 PM
selonoid open?
Yep, that's it.
  • WHdbJD and DennyIN have said thanks
#9 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,471 Thanks
  • 5,770 posts
Posted June 18, 2015 - 08:53 PM
It may also be causing the power module's relay to stop telling the fuel S/off to open.  Pull off the right side cover and look behind the radiator.  With the PTO switch off and the brake depressed a green LED is lit on the board that means it is OK to run.  The Fuel S/off solenoid is on the left side of the engine and when the green light is turned on you will hear a loud click and see the rod extend to open the fuel flow.  That's pretty much all there is to it..
  • Trav1s, WHdbJD, Alberta Bolens and 1 other said thanks
Also tagged with one or more of these keywords: j d 455
