For Sale
Kohler M20: Ariens GT20
4 replies to this topic
#1 djordje33 OFFLINE
djordje33
  • 25 Thanks
  • 69 posts
Posted June 18, 2015 - 07:22 AM
Kohler M20 horizontal twin engine, Spec. 49533, 1-1/4" PTO crank OD #52-014-71-S
Complete with front PTO clutch, starter, newer carb and fuel pump, cold air cleaner assembly, engine tins, and muffler.
This was pulled from a running GT20. Hours estimated at less than 900. Hour meter stopped working 2 years prior due to the electrical fairies which plague these systems and it was stopped at 720. This engine is complete, but like anything else a little TLC will go a long way. (cleaning, gaskets, plugs, etc) These are very hard to find intact and parts are worth their weight in gold. New crank is $890, Ariens PTO is over $600, etc. Engine is still in crate as received. I originally purchased it for a drop-in on one of my GT18's, but opted to completely rebuild the M18 and keep both tractors identical one another. The newer Kohler commands cannot even come close to the torque and longevity of these Magnums which is why I invested in rebuilding mine from scratch.
Asking $750. A rebuilt Magnum 20 would run upwards of $1500 and if you can find a new one, it would be well over $2000.   For pick up only in Northeast Ohio. May consider trade options in the form of a super clean 42" or 48" mower deck for the Ariens GT series, front end loader (either drop in or something which can be retrofitted),
Edited by djordje33, June 19, 2015 - 07:45 AM.
  • laurarg3 said thank you
#2 djordje33 OFFLINE
djordje33
  • 25 Thanks
  • 69 posts
Posted July 07, 2015 - 10:32 PM
If someone has an offer in mind, doesn't hurt to throw it out. Aside from cash, I'd be interest in a super clean deck with shaft, 3-pt shaft drive tiller, or front end loader. I could even meet someone within reasonable distance of Cleveland, OH.
#3 Split51 OFFLINE
Split51
  • 3 Thanks
  • 9 posts
Posted July 09, 2015 - 06:49 PM
Djordje. Could I get you to send me that crank end spec sheet for the M20? I need to replace an M20 and that chart is what I have been hunting for. I can't quite see the measurements on here.
Blairsigns@yahoo.com
Thanks, Jeff
Edited by Split51, July 09, 2015 - 09:38 PM.
#4 djordje33 OFFLINE
djordje33
  • 25 Thanks
  • 69 posts
Posted July 14, 2015 - 02:33 PM
sent.
#5 LavGal OFFLINE
LavGal
  • 1 posts
Posted May 19, 2016 - 01:15 PM
Do you still have this M20 engine?
