Ignition Switch
11 replies to this topic
#1 Wm McNett OFFLINE
Wm McNett
  • 125 Thanks
  • 169 posts
Posted June 17, 2015 - 05:36 PM
Who makes a good 6 terminal ignition switch?
The one I bought off Jacks using the Ariens part number 2 years ago started giving me fits last year.
Figured out the offset "I" terminal that powers the coil is not supplying power in start.
Today I noticed it was loose and if I hold it just right it will supply power in start.
GT19 Kohler KT19 series II battery points ignition.
Edited by Wm McNett, June 18, 2015 - 08:54 AM.
  • laurarg3 said thank you
#2 Bolens 1000 OFFLINE
  • 14,906 Thanks
  • 18,104 posts
Posted June 17, 2015 - 05:46 PM
Whats the part number you got?
Almost all ignition switches are made by the same company (Indak)
#3 Wm McNett OFFLINE
Wm McNett
  • 125 Thanks
  • 169 posts
Posted June 18, 2015 - 08:53 AM
Ariens 53123700
  • Bolens 1000 said thank you
#4 Bolens 1000 OFFLINE
  • 14,906 Thanks
  • 18,104 posts
Posted June 18, 2015 - 09:00 AM
Its just a regular indak, could have been a rare defect.
No matter where you buy from they all use indak as their supplier for this part
  • Wm McNett said thank you
#5 Wm McNett OFFLINE
Wm McNett
  • 125 Thanks
  • 169 posts
Posted June 19, 2015 - 06:59 AM
$40+ later I ordered another one, then tore mine apart re-staked the "I" terminal, bent the plate that connects to it a little and re-assembled it. We'll see how it goes after yesterdays rain gets burned off ;)
Edited by Wm McNett, June 19, 2015 - 06:59 AM.
#6 Wm McNett OFFLINE
Wm McNett
  • 125 Thanks
  • 169 posts
Posted December 12, 2016 - 05:36 PM
Broke down and installed my new switch afer it snowed, the neighbor has been mowing so I haven't needed it.
Needless to say, same issue, no power to the coil during cranking.
I'm going to guess the diode on the battery terminal is burned out.
I have a few larger ones in my box of electronic stuff, some Packard 56 terminals, connectors, Delphi chimpers, and heat shrink tube so I'll build another one and swap it out.
Sent from my SM-G920P using Tapatalk
#7 shorty ONLINE
shorty
  • 5,287 Thanks
  • 5,169 posts
Posted December 13, 2016 - 06:49 AM
Very frustrating when new parts don't work like they should. I wired in a push button start when my switch went bad. Not a perfect fix, but it gets the job done.
#8 Wm McNett OFFLINE
Wm McNett
  • 125 Thanks
  • 169 posts
Posted December 13, 2016 - 12:23 PM
New dual 6 amp 400 volt diode assembly, just needs a little insulation
I order a few more doides from allelectronics.
I can make them for a 1/10 of what the Ariens part costs.
  • Cvans and Scrapr65 have said thanks
#9 Cvans OFFLINE
  • 6,467 Thanks
  • 6,058 posts
Posted December 13, 2016 - 01:23 PM
I would think those buggers ought to do the job.  :D
#10 Wm McNett OFFLINE
Wm McNett
  • 125 Thanks
  • 169 posts
Posted December 14, 2016 - 02:24 PM
Here's my original
Which is a IN5404 = 3 amp 400 volt
With my meter, I have continuity in both directions. I would have assumed that it would read open.
I looked up the new Ariens part and you can see they used 2 that are huge, similar to what I have now.
  • Cvans said thank you
#11 Bolcaltrix OFFLINE
Bolcaltrix
  • 1 posts
Posted August 03, 2017 - 11:54 PM
Ariens ​pn 53123700 ignition switch replacement is a STENS 430-954, cost is 1/3 Ariens' price.
Bought one for $15.00 for my GT-17; works fine.
#12 dodge trucker OFFLINE
dodge trucker
  • 2,304 Thanks
  • 3,017 posts
Posted August 04, 2017 - 12:11 PM
Response to an old Post but I'm glad you did cuz I have 2 that I am working on right now with wiring and switch issues and know that on the gt19 at least I will need an ignition switch for it
