ss12 shifter fixed
4 replies to this topic
#1 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted June 17, 2015 - 11:57 AM
I know there are some that won't like what I did to fix the shifter on my "67 ss12.  Instead of removing the transmission to take the shifter out, I just took my angle grinder and made the opening in the frame, where the shifter sticks up, a little larger.  I removed the 4 bolts, pulled the shifter out and sure enough,, things had been jammed out of whack.  I took a screwdriver, stepped on the clutch, click, click, and things were back to normal. I put the shifter back in and all gears worked fine again.
Thank You all that offered suggestions.
Robert
  • MH81, EricFromPa, KennyP and 2 others have said thanks
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted June 17, 2015 - 12:42 PM
Whatever works! It's your tractor.
  • tinbender7 said thank you
#3 MNGB OFFLINE
MNGB
  • 2,138 Thanks
  • 1,417 posts
Posted June 17, 2015 - 12:43 PM
Hi robert_p43, good to hear your back up and running, I say what ever it takes and works is good its your tractor and you saved yourself a lot of work.
#4 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted June 17, 2015 - 12:46 PM
There are times when you just have to 'git-r-dun!
#5 MH81 OFFLINE
Posted June 17, 2015 - 09:38 PM
I've always thought that hole could've been a little bigger for just such situations.
Glad you got it fixed!
The MF10/12 was just big enough to get in there when we needed to...
The last tranny swap we did was a little north of 2.5 hours, incl transferring brake parts and finding a pulley that made us all happy and cleaning up some exposed frame areas.
  • olcowhand said thank you
