Bolens Ridemaster
4 replies to this topic
#1 Littlebird OFFLINE
Littlebird
  • 3 Thanks
  • 3 posts
Posted June 17, 2015 - 06:22 AM
Does anyone have a photo of the reverse drive disc for the Bolens Ridemaster?  What is this disc made out of?  Dimensions?  Thanks!
Bolens Ridemaster Type 35AB301  Serial R15024
Kevin Golden
Harrisonville, MO
  • laurarg3 said thank you
#2 chieffan OFFLINE
  • 16594 Thanks
  • 9088 posts
Posted June 17, 2015 - 07:09 AM
I have no idea what it is made out of but looks about like the same material a brake pad is made from. It is tapered on both sides and fits into the mating "V" type grove on the inside engine pulley. Check with a couple of the suppliers on this site. That is where I got mine but don't remember who it was I got it from but believe it was Bolens1000. They are price so be prepared. When you get the new on be sure it matches up exactly with the engine drive pulley or it will wear off on one side and won't pull. You might want to start getting the motor pulley soaking so in case you do have to move it you will be able to do so. Good luck.
Edited by chieffan, June 17, 2015 - 07:59 PM.
  • Gtractor, Alc and Littlebird have said thanks
#3 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted June 18, 2015 - 08:40 PM
Sounds like your talking about a ride a matic his tractor is a ridemaster.
  • chieffan said thank you
#4 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted June 18, 2015 - 08:44 PM
Kevin Golden
Harrisonville, MO
What is wrong with yours?  These don't were out very often..
I also see your tractor is a two speed by the numbers.
Brake fiber, Brass, or aluminum will work.
  • Bruce Dorsi said thank you
#5 chieffan OFFLINE
  • 16594 Thanks
  • 9088 posts
Posted June 18, 2015 - 10:36 PM
Your right and I was wrong.  Guess I better get my good glasses on.
  • wilberj said thank you
