Dumb Question
24 replies to this topic
#16 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted June 17, 2015 - 07:27 AM
Thanks Kenny,hope it's not my valves but if so,this will come in handy.
#17 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted June 17, 2015 - 07:30 AM
Ok so if it ain't the cap plugged I will tear the cylinder apart and reseal it. Change fluid and filter and ad some lucas,just as a precaution. Thanks guys. I will update when I find something new out.
#18 KennyP OFFLINE
  • 51076 Thanks
  • 52665 posts
Posted June 17, 2015 - 08:23 AM
It's always nice to see what is inside there. Most likely the cylinder, but you never know!
#19 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted June 17, 2015 - 09:29 AM
That's true Kenny. You can never too much info.
#20 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted June 17, 2015 - 11:54 PM
Along with all the other bits and pieces, there is also an o-ring between the piston and the rod.
Do a little judicious cleanup of the base end of the cylinder. The piston comes out there, not the head end. Remove the base end fitting before trying to push out the plug.
Who put the Eaton in a MF1655? The Snappers came with Eatons, the MF's came with Sundstrands.
Edited by TUDOR, June 17, 2015 - 11:55 PM.
#21 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted June 18, 2015 - 06:08 AM
Thanks Bob,i have one here already tore apart. I think this is a Snapper actually. The hood.side panels and fenders are all MF red with decals.but the frame is all dull snapper red.
#22 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted June 18, 2015 - 09:24 PM
So I was grading the driveway today and when it started loosing lifting power,i unscrewed the filler cap. No gush of air this time,and no change in operation. So I guess I will be rebuilding this cylinder.
#23 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted June 28, 2015 - 09:25 AM
Well I swapped out the cylinder from another tractor that is known good. And no change. So I guess it must be the valve that's bad.
#24 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted June 28, 2015 - 02:47 PM
Sorry to hear it, hope you can find one for reasonable.
#25 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted June 28, 2015 - 03:38 PM
I think I might have a spare block or 2 on in a bin. If not, I hope I can find a good used one cheap too.
