turning on the mower deck
19 replies to this topic
#16 Glenn Ayers ONLINE
Glenn Ayers
  • 63 Thanks
  • 86 posts
Posted June 20, 2015 - 08:42 PM
Hi Joey, per the instruction for installing a 48" deck with a parallel hitch the mule drive belt goes on the top pulley groove. I attached a manual see page 4
 Glenn some deck have a 3 groove center pulley.
attachicon.gifParallel hitch.pdf
I don't think Joey has that newer style deck that you posted the manual for.
Joey ....  please also ignore where someone stated to make sure your spring loaded cross-deck pulley tensioners are set right.  Your old style deck doesn't have spring loaded cross-deck tensioners.  It should just have bolt adjustable idler pulleys that should ride against the non-driving side of the belt  .... ie ... the left belt tensioner should ride against the flat part of the left belt on the front.  The right belt tensioner should ride against the flat part of the belt on the back.  See drawing.
Edited by Glenn Ayers, June 20, 2015 - 08:43 PM.
  • MNGB said thank you
#17 joey7478 OFFLINE
joey7478
  • 3 Thanks
  • 54 posts
Posted June 21, 2015 - 10:34 AM
Thanks everybody Joey!
#18 joey7478 OFFLINE
joey7478
  • 3 Thanks
  • 54 posts
Posted June 29, 2015 - 03:44 PM
#19 joey7478 OFFLINE
joey7478
  • 3 Thanks
  • 54 posts
Posted June 29, 2015 - 03:46 PM
My tensioners are both on front of belts not one in back. Has some one moved one ?
#20 Glenn Ayers ONLINE
Glenn Ayers
  • 63 Thanks
  • 86 posts
Posted June 29, 2015 - 05:45 PM
I've seen them both in front from the factory .... but that doesn't mean it's correct.   Think about it.
  • joey7478 said thank you
