sears tractor
17 replies to this topic
#16 MH81 OFFLINE
Posted June 16, 2015 - 11:30 PM
This is going to sound like an odd question, but if you lift the rear off the ground, does the shifting problem still happen?
For instance, put it on jack stands and see if there is a change.
These tractors do not have bearings on the axels, only bushings and they are prone to wearing thru, allowing the axel to have an unplanned for angle, causing binding.
Brake linkage and adjustment can hinge on the clutch and vice versa
#17 dennis55 OFFLINE
dennis55
  • 7 Thanks
  • 28 posts
Posted June 17, 2015 - 12:49 PM
thanks for all the help so far..tried again today, i dont know its name but in the picture i labeled it(a) it was a little loose so i put some washers(b).(didnt work). from any of these pics can anybody see something wrong
#18 dennis55 OFFLINE
dennis55
  • 7 Thanks
  • 28 posts
Posted June 17, 2015 - 12:52 PM
above
