Wisconsin AKN and ABN crankshaft interchange.
4 replies to this topic
#1 classic ONLINE
classic
  • 5,164 Thanks
  • 2,227 posts
Posted June 16, 2015 - 10:53 AM
I was wondering if a Wisconsin ABN crankshaft can be used in a Wisconsin AKN engine. Working on Wisconsin engines is new to me. Thanks.
  • laurarg3 said thank you
#2 Bolens 1000 ONLINE
  • 14,891 Thanks
  • 18,098 posts
Posted June 16, 2015 - 11:04 AM
The numbers will be stamped on the cast iron weights , thats the only way to tell, these crankshafts on these engines did not have a common number given in the Wisconsin literature.
#3 classic ONLINE
classic
  • 5,164 Thanks
  • 2,227 posts
Posted June 16, 2015 - 11:50 AM
Thanks. My dilemma is that I have an AKN with a hole in the block and it's a gear reduction engine. I can get an ABN engine with the same gear reduction unit and I was wondering if the crankshafts would be the same. The stamped numbers on my crankshaft are CA-51-65. I can also get another AKN block to replace mine.
#4 Bolens 1000 ONLINE
  • 14,891 Thanks
  • 18,098 posts
Posted June 16, 2015 - 12:01 PM
The connecting rods are the same between the two engines , but the ABN used a different Flywheel than the AKN so you would probably have to swap those out as well.
  • classic said thank you
#5 classic ONLINE
classic
  • 5,164 Thanks
  • 2,227 posts
Posted June 16, 2015 - 12:37 PM
Thanks, I appreciate the info. The crankshaft is my main concern and is the deciding factor on picking up the ABN engine.
