sears st16 drive belt size
8 replies to this topic
#1 jpd112294 OFFLINE
jpd112294
  • 3 Thanks
  • 10 posts
Posted June 15, 2015 - 09:33 PM
hello folks. does anyone know what size drive belt a sears st16 uses? mine broke into 3 pieces on my loader tractor months ago and i havent needed it since then.
Edited by jpd112294, June 15, 2015 - 10:09 PM.
  • laurarg3 said thank you
#2 JBRamsey ONLINE
JBRamsey
  • 1,474 Thanks
  • 841 posts
Posted June 15, 2015 - 10:28 PM
Go to the manuals section and you can find the sears number there then cross it to a regular belt number. I got the belt for my Super 12 from there and it fit perfectly.image.jpg
#3 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted June 16, 2015 - 06:59 AM
I do have American made kevlars instock if you dont have luck locally
https://bolenspartsa...4h-6774h-84352/
What ever you decide do not get an automotive belt.
#4 KennyP ONLINE
  • 38,491 Thanks
  • 45,979 posts
Posted June 16, 2015 - 07:54 AM
If I looked up the correct tractor, it's a Sears 6474H. According to that list above, it's a 5/8" X 81".
#5 JBRamsey ONLINE
JBRamsey
  • 1,474 Thanks
  • 841 posts
Posted June 16, 2015 - 07:42 PM
That will be a 5L810.
#6 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted June 16, 2015 - 08:16 PM
The size is correct but any "L" series belt is not power rated and for "Light duty"
  • 6mikey7 said thank you
#7 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted June 17, 2015 - 09:03 PM
I have a v-belt question about 5L vs B.
Since a B78 v-belt is similar dimensions to the 5L810.
I've read that the 5L means light-duty (FHP - fractional horse power).
Is a B78 belt what we need?
Edited by motobreeder, June 17, 2015 - 09:04 PM.
#8 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted June 18, 2015 - 06:47 AM
Dimentions are the same its the materials that are different
L series are Light duty , most used in driving electric motors ,fans ect.
B Series is power rated but not a kevlar corded & covered belt, these are NOT for  clutching applications!
Kevlar belts are what should be used on these machines for proper performance and durability, they are designed for the severe clutching and twisting experienced with most L&G applications
#9 TAHOE OFFLINE
TAHOE
  • 7,978 Thanks
  • 5,676 posts
Posted June 18, 2015 - 11:45 AM
I use the 5L810K from TSC for my drive on my ST16, it's Kevlar and seems to last. Jerked my head off and wheelied across the yard the first time I popped the clutch after install
