PK K361 running abit ruff and afterfire
2 replies to this topic
#1 MNGB ONLINE
MNGB
  • 1,970 Thanks
  • 1,335 posts
Posted June 15, 2015 - 07:47 PM
A few days ago when using the Pk to pile up a bunch of branches the Kohler would run a bit ruff and sometimes there would be after fire, this happen last summer and it turned out to be a lose mounting bolt that holds the coil and condenser found it by noticing the sparking at the bolt tightened it an all was good. Well Friday  I got the PK into the shop to change oil and service it first I used the FEL to move some stuff and it started the ruff running more and more, so while changing oil and servicing the tractor I cleaned the fuel filter cleaned the airfilter & pre-filter cleaned ckd the gad and tested the S plug I could see by the soot on the plug that the engine wasn't running lean, checked the plug wire the coil end was a little corroded so installed a new wire core wire started the engine and it ran the same, it was supper time so that evening I was thinking about it and wondered if the condenser was the problem  so Saturday I installed a new condenser and now it runs like new again have run it about 45 minutes no problems.
  • Alc, propane1 and WilliamSa have said thanks
#2 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,988 Thanks
  • 9,632 posts
Posted June 15, 2015 - 08:56 PM
You maybe know about the issues with the k361 running hot. Be sure the cooling fins are clean.
  • MNGB said thank you
#3 MNGB ONLINE
MNGB
  • 1,970 Thanks
  • 1,335 posts
Posted June 15, 2015 - 08:59 PM
Hi LilysDad, oh yes I'm aware of that and watch it close, mine is a good running one and I don't want anything to hurt it.
