Husky mtd front wheel bearings?
4 replies to this topic
#1 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 11,137 Thanks
  • 6,483 posts
Posted June 14, 2015 - 05:03 PM
Buddy of mine bought a husky tractor. It's an mtd looks exactly like the yard man dad bought years ago. Gear shift in the center for forward and reverse and beside that is a lever for gears 1 thru 7(?)
The front wheel bearings are shot the wheels are flopping on the spindle all that's hold them in place is the nut.
What can be done? I haven't pulled it apart but I fear it may be too late to salvage the spindles and rims
Are they sleeves or bearings?
  • KennyP and laurarg3 have said thanks
#2 boyscout862 ONLINE
  • 13,693 Thanks
  • 9,476 posts
Posted June 14, 2015 - 05:41 PM
In the Manuals Section is an really good set of 3 MTD manuals. Check them for the info you need. I have a bunch of old MTD LTs that I will be stripping and junking. Maybe I can help. Good Luck, Rick
#3 KennyP ONLINE
  • 41,503 Thanks
  • 47,416 posts
Posted June 14, 2015 - 05:55 PM
Sounds like my old MTD Ranch King. Front wheels had plastic sleeves that were greasable. Never could figure that out!
#4 glgrumpy OFFLINE
  • 8,849 Thanks
  • 8,036 posts
Posted June 14, 2015 - 06:21 PM
Had plastic bushes also in MTD. My Speedex have 1" axles and metal bushings, but are bad many times when getting them. Problem for those is the wheel is only the standard 1-3/8" hub and no bearing for those then. I did get bushings from Mc-master.com that worked, but are hardened ones and little pricey. I also just bought some wheels today that had 1" bore bearings in them, BUT the hub on wheels are much larger also to accept them. They even have races in them for the bearings I believe. Just pull a wheel and SEE what's there. Measure axle diam and hub of wheel sizes and go from there. IF you have just 3/4" axles, bearings in many stores for those, but a 1" axle is going to need bushings as noted.
#5 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 11,137 Thanks
  • 6,483 posts
Posted June 14, 2015 - 07:02 PM
Thanks. I'll pull it apart tomorrow and see what I can see. Tractor is at the camp. I hope I can figure something out
