Looking for a heavy duty tractor
15 replies to this topic
#1 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted June 14, 2015 - 12:37 PM
Murray 11/36 rear axle took a dump.  Motor is in great shape.  Deck can be refurbed-has new spindles, took it off to use tractor for yard-dog.
Looking for heavy duty tractor to rebuild into another yard-dog.
No light-weights.  Used to pull 2 ton logs with log arch.
Original setup:126.jpg
  • Traill95 and Sawdust have said thanks
#2 OldBuzzard OFFLINE
OldBuzzard
  • 6,984 Thanks
  • 4,783 posts
Posted June 14, 2015 - 01:05 PM
Bolens H16, largest of the tube frames. Locking rear diff.  Will pull those logs with no problem.
http://sarasota.crai...5066860095.html
  • boyscout862 and Phluphy have said thanks
#3 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,546 Thanks
  • 961 posts
Posted June 14, 2015 - 01:33 PM
Nice looking tractor and very good price, hey if you had to wander from the original paint theme , be hard pressed to find fault with his choice, if it was closer....
  • Sawdust said thank you
#4 boyscout862 ONLINE
  • 12,545 Thanks
  • 9,043 posts
The Murry was a lawn tractor(LT). It has an aluminum transaxle. An old Bolens has a rugged castiron transaxle. Any of the name brand garden tractors will be better than an LT. If that H16 is in good shape, thats a good deal. It has hydraulic lift to make work easier. If you get it you can download the manual from our Manuals Section for free. Good Luck, Rick
Edited by boyscout862, June 14, 2015 - 01:35 PM.
  • Sawdust and Phluphy have said thanks
#5 Sawdust OFFLINE
Sawdust
  • 5,562 Thanks
  • 3,335 posts
Posted June 14, 2015 - 02:41 PM
OB you sure that's an H16...inside joke between buddies.:)
  • Bolens 1000 and boyscout862 have said thanks
#6 Sawdust OFFLINE
Sawdust
  • 5,562 Thanks
  • 3,335 posts
Posted June 14, 2015 - 02:45 PM
Yeah you pulled the guts out of that. Like mentioned find any of the old classics in good shape. Be careful with some of the new stuff....big engines & no frames.
#7 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted June 14, 2015 - 05:04 PM
Don't know how to reply to the listing, but, thank you.  I'm 2 1/2 hours north in Crystal River, better half sez I'm not going that far for another toy.  :mad2:
#8 boyscout862 ONLINE
  • 12,545 Thanks
  • 9,043 posts
Posted June 14, 2015 - 05:21 PM
Tell her she is right. Just keep your eyes open for something local. When you have questions, we are here to help. Good Luck, Rick
#9 EricFromPa ONLINE
EricFromPa
  • 3,525 Thanks
  • 3,071 posts
Posted June 14, 2015 - 06:50 PM
Dude this one looks like it was Built for you.It's north of you a ways though.
http://lakecity.crai...5038096162.html
  • Phluphy said thank you
#10 MH81 OFFLINE
Posted June 14, 2015 - 08:25 PM
Toy?         TOY?
Has she ever tried dragging in wood without one?
Tell Her she's pronouncing it wrong...
TOOL
(prounounced: tuːl)
a thing that helps you to do your job or to achieve something
:poke:
#11 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted June 14, 2015 - 09:38 PM
Thanks guys.
No, she sez taking care of the trees etc. on our 5 acres is my job, but tells me to be careful, don't hurt yourself, and, a bit myopically, says, can't you just cut them up and use the wheel barrow?
Really!  43 years of marriage to someone with a slight mechanical deficiency, has been a bit of a challenge.
Does agree, the one in Fort White is closer, thinking a heaping plate of homemade brownies will add some leverage.
#12 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 14, 2015 - 10:29 PM
well you sure got your moneys worth out of that little Murray. That log Arch has to weight more, not even counting any logs.
Keep your eyes open for a Garden tractor. Doing what you are I would not rule out a small to medium size farm tractor.
It is one thing to pull a load like you are talking about. It is a whole other story trying to stop that load!
My property is hilly and I would give a load of 3,000 lbs some serious thought, before I tried to move it with my Ford 1500 and it weighs 2,ooo lbs. I would do it, but would first plan an escape route.
When things go wrong, you want to live and get a second chance!
Edited by JD DANNELS, June 14, 2015 - 10:32 PM.
#13 OldBuzzard OFFLINE
OldBuzzard
  • 6,984 Thanks
  • 4,783 posts
Posted June 15, 2015 - 01:27 AM
I've always found it easier to ask for forgiveness than for permission  :D :D :D
  • MH81 and Sawdust have said thanks
#14 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted June 15, 2015 - 11:03 AM
Right you are, but, our property is table-top flat.  The arch is a bit deceptive, only weighs 200 lbs. including the water tank/counter weight filled. And, definitely got money's worth out of the Murray over the past 7 years.
#15 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted June 15, 2015 - 01:54 PM
