MTD goes in reverse but not forward! Please Help!
5 replies to this topic
#1 dannkim OFFLINE
  • 1 Thanks
  • 1 posts
Posted June 11, 2015 - 04:31 PM
My riding will move in reverse but will not in forward. The higher speed selection the louder the noise; the noise is almost like a metal chatter. I have replaced the transmission belt (upper drive belt). I have taken the transmission apart and could see no visible indications of bad pieces. I can turn the gears by hand when the transmission is out.
If my lower drive belt (goes to engine) is bad and needs replaced, would I still be able to go in reverse? I would expect my reverse to be out also not just forward.
All 3 positions fully engage by hand. If in the forward position wheels are locked and will not roll. In the neutral position, wheels are not locked and can push. In the reverse position, wheels are locked and it will engage on its own. The only problem I have is getting it to move forward. I currently have transmission out and the collar has very, very, very slightly beveled edges. If I had to guess, the collar does not look like the problem.
Pictures: Collar and Forward gear
My info:
Yard Machine
Model # 13A1762F700
Year- 2006
Variable drive- not hydrostatic
  • chieffan said thank you
#2 boyscout862 OFFLINE
  • 13,191 Thanks
  • 9,279 posts
Posted June 11, 2015 - 04:45 PM
Welcome to GTT. We have some good manuals that you can download in our Manuals Section( 3 for free per day). Good Luck, Rick
#3 Bill 76 ONLINE
Bill 76
  • 1,950 Thanks
  • 1,197 posts
Posted June 11, 2015 - 05:42 PM
I would check the shift fork to see if it's bent,looking at your pictures I can see the rounded edges on the shifter clutch's (that's what we called them on old Harleys) once they lose the sharp edge they will push them self's apart if the shift fork is not engaging  them fully and the noise your hearing is probably them bouncing off each other.If you can get them to engage  fully I think the problem would go away. you might be able to shim the side gear in to get full engagement.
I am not familiar with your machine but other members may have a better idea.
  • boyscout862 and Chopperhed have said thanks
#4 Chopperhed OFFLINE
  • 1,852 Thanks
  • 1,071 posts
Posted June 11, 2015 - 07:05 PM
I've always called them a dog clutch, They are used in the transmissions of outboard engines, among other things. I suspect the linkage is out of adjustment, and are not letting them engage properly. As Bill said, since I'm not familiar with the machine, I can't say for sure.
Edited by Chopperhed, June 11, 2015 - 07:09 PM.
#5 crittersf1 OFFLINE
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 12, 2015 - 07:34 AM
#6 TomLGT195 OFFLINE
  • 3,920 Thanks
  • 2,846 posts
Posted June 12, 2015 - 07:46 AM
:welcometogttalk:   Sorry I bring nothing to the table for this one. Just saying hello and enjoy the site, lots of nice people here.
