My SS15
331 replies to this topic
#76 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted July 14, 2015 - 09:29 PM
I'm about to buy a bigger tractor and I might have to sell my Sears SS15 to put the money toward the tractor I don't want to but I might have to. Anyway can anybody tell me whats it worth ? It has a new carb,points,condensor,magento and keyswitch I will also be selling it with it attachments ( Moldboard plow , Foot Plow , Cultivator and Disc). It also has a brand new set of Super lugs on the rear.
#77 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted July 20, 2015 - 12:19 PM
Ran it out of gas last night now it won't stay running without the choke
#78 TAHOE OFFLINE
TAHOE
  • 7,748 Thanks
  • 5,583 posts
Posted July 20, 2015 - 02:19 PM
Sucked up some crud, sound like carb teardown and cleaning time.  You have to remove the main jet first if you want to separate top/bottom carb halves....many times they strip out.
Edited by TAHOE, July 20, 2015 - 02:19 PM.
#79 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted July 20, 2015 - 02:21 PM
brand new carb I was thinking fuel pump
#80 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted July 20, 2015 - 02:22 PM
I did get it going it just took a hour
#81 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted July 26, 2015 - 11:29 PM
I finally took the new carb apart and fixed the float so it would stop leaking I also think I finally got the carb tuned right fires right up and runs smooth
  • MH81, Alc and KennyP have said thanks
#82 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,762 Thanks
  • 4,303 posts
Posted July 27, 2015 - 07:39 AM
Good deal.
#83 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted July 30, 2015 - 09:20 PM
How many gallons of windshield washer fluid go in each tire ? I think my tires spinning probably what caused my belt to stretched.
#84 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,762 Thanks
  • 4,303 posts
Posted July 30, 2015 - 10:09 PM
I did a search and found this.
Dico 26x12x12 rears I put 4 gals each and the rest water and they each went from a prefill weight of 44 lbs to 140 and 139 lbs filled weight.
http://gardentractor...027#entry542027
And this
http://www.mytractor...lled-tires.html
Hope this helps in your decision. Wheel weights may be better, but shipping is a killer. I have some tire chains that you can try.
  • bbuckler said thank you
#85 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted July 31, 2015 - 06:27 AM
http://gardentractor...ht-to-your-r111
http://gardentractor...712#entry402712
http://gardentractor...e-filling-tank/
  • wvbuzzmaster and bbuckler have said thanks
#86 craftsmanmowerfreak ONLINE
craftsmanmowerfreak
  • 283 Thanks
  • 229 posts
Posted August 02, 2015 - 09:45 AM
spinning tires cant stretch a belt. its very hard to stretch a belt. many times when someone says belt is stretched its not stretched its plain wore out. your machine takes a 5/8s by 82 inch belt get it at tractor supply. kevlar wrapped and will last for years unless you have a bad pulley and belt gets hung up or dont route  it right,. thats usually only time i see drivebelts on these go bad unless they are real old
#87 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted August 02, 2015 - 01:46 PM
I feel like an idiot the belt just came off the idler pulley it wasn't stretched
#88 bbuckler ONLINE
bbuckler
  • 3,204 Thanks
  • 2,880 posts
Posted August 05, 2015 - 09:30 AM
#89 craftsmanmowerfreak ONLINE
craftsmanmowerfreak
  • 283 Thanks
  • 229 posts
Posted August 05, 2015 - 09:34 AM
lol tsc time. that belt looks like a 1/2 and not a 5/8 lol. remember size is 5/8 x 82
Edited by craftsmanmowerfreak, August 05, 2015 - 09:35 AM.
#90 Bolens 1000 OFFLINE
  • 14,809 Thanks
  • 18,056 posts
Posted August 05, 2015 - 09:40 AM
Or an American made one :D
https://bolenspartsa...5r-48044-5091h/
