My SS15
331 replies to this topic
#61 MH81 OFFLINE
Posted July 02, 2015 - 08:12 PM
I just went thru the thread, based on the pics in this post http://gardentractor...e-3#entry584250
It can't be a ground to kill.
A toggle switch will provide power for the coil, a second would run the solenoid.
It wouldn't be pretty, but it would work.
It does have a solenoid?
  • rustyoldjunk and wvbuzzmaster have said thanks
#62 bbuckler ONLINE
bbuckler
  • 3,319 Thanks
  • 2,980 posts
Posted July 02, 2015 - 08:54 PM
The toggle switch was for the external coil but it was replaced with a mag. Yes it has a new solenoid.
Edited by bbuckler, July 02, 2015 - 09:00 PM.
  • rustyoldjunk said thank you
#63 MH81 OFFLINE
Posted July 02, 2015 - 09:03 PM
Ok, so it has the mag again?
I missed that.
Ok, so you should have a ground to kill system.
Same two switches, but one will provide power to the solenoid... The other will be grounded and will short the mag kill wire to ground.
Verify what I'm saying before proceeding.
  • rustyoldjunk, wvbuzzmaster and bbuckler have said thanks
#64 bbuckler ONLINE
bbuckler
  • 3,319 Thanks
  • 2,980 posts
Posted July 02, 2015 - 09:05 PM
I missed that.
I ordered the right switch but is there a way to start it without the switch so I can start plowing
#65 MH81 OFFLINE
Posted July 02, 2015 - 09:09 PM
Do you have a solenoid?
  • wvbuzzmaster said thank you
#66 bbuckler ONLINE
bbuckler
  • 3,319 Thanks
  • 2,980 posts
Posted July 02, 2015 - 09:16 PM
Yes but I can't cross it because where the solenoid is located.
#67 MH81 OFFLINE
Posted July 02, 2015 - 09:22 PM
Ok, one of the wires to the switch was the wire that goes to the solenoid. It would've been on the S terminal
#68 bbuckler ONLINE
bbuckler
  • 3,319 Thanks
  • 2,980 posts
Posted July 02, 2015 - 09:38 PM
Yep s - solenoid m- magneto g- ground
Edited by bbuckler, July 02, 2015 - 09:38 PM.
#69 MH81 OFFLINE
Posted July 02, 2015 - 09:40 PM
Ok, take the wire from S and apply power; starter turns over.
When engine starts, short M to Ground and it shuts off.
  • wvbuzzmaster and bbuckler have said thanks
#70 bbuckler ONLINE
bbuckler
  • 3,319 Thanks
  • 2,980 posts
Posted July 03, 2015 - 08:45 AM
  It wasn't the keyswitch the end I put on the wire going to the solenoid fell off. At least I will the right keyswitch now.
#71 MH81 OFFLINE
Posted July 03, 2015 - 11:15 AM
Just make sure the switch has a M on it. :D
#72 bbuckler ONLINE
bbuckler
  • 3,319 Thanks
  • 2,980 posts
Posted July 04, 2015 - 07:59 AM
I got to fix the new carb today before plowing it leaking around the bowl gasket I never adjusted the float on it
#73 bbuckler ONLINE
bbuckler
  • 3,319 Thanks
  • 2,980 posts
Posted July 05, 2015 - 03:41 PM
It stalled out today on me I'm going to try the old carb.
#74 bbuckler ONLINE
bbuckler
  • 3,319 Thanks
  • 2,980 posts
Posted July 05, 2015 - 04:48 PM
#75 bbuckler ONLINE
bbuckler
  • 3,319 Thanks
  • 2,980 posts
Posted July 11, 2015 - 06:07 PM
Didn't sell much today but while we was waiting me and my uncle re wired the ss15 , added the new keyswitch and new throttle cable
Edited by bbuckler, July 11, 2015 - 06:24 PM.
  • MH81, KennyP and TAHOE have said thanks
