Still runs rough my uncle swears it the points causing the problem.
https://www.youtube....eature=youtu.be
Posted June 18, 2015 - 11:05 AM
Posted June 18, 2015 - 11:20 AM
i just seen video on fb take pics of points how they are hooked up and everything.
Posted June 18, 2015 - 12:56 PM
k i see you got a kohlor coil on it make sure the coil has a internal resistor built in. if not it will cause it to run like it did in video and eventually burn points up. all 3 big cast iron briggs of mine still has mag hooked up. i never had a issue with it. my sub 14 when i got it had a nova ignition installed that i removed. when i pulled points cover had new points and condensor. but i will say one thing if you do hook mag up to points again make sure flywheel key is good or you wont get spark. but the kohlor coil should work fine if it has internal resistor
Posted June 18, 2015 - 12:59 PM
also make sure points are gapped to 20 thousandths
Posted June 18, 2015 - 01:20 PM
No spark now after that pic. also that coil has a dodge logo on it.
Posted June 18, 2015 - 01:30 PM
that would more than likely be issue theres no internal resister
Posted June 18, 2015 - 01:36 PM
The part list don't show a external coil for the model. I think it had a internal coil probably went bad and the guy rigged up this setup.
Posted June 18, 2015 - 01:54 PM
yes the coil on it is not original. because mine has mag over flywheel on the 3 running cast iron briggs i got
Posted June 18, 2015 - 02:05 PM
Have you cleaned the points since that picture above? They look pretty dirty in that picture
Posted June 18, 2015 - 02:26 PM
I'm going to go ahead and buy one when I order the points
Posted June 18, 2015 - 09:04 PM
I planning on painting again after I get it going good again. This color is a lighter blue I think it might be close to what I want.
http://www.tractorsu...w-ford-n-h-blue
Posted June 19, 2015 - 03:38 PM
Will the cable part work to replace the old one ? http://www.lowes.com...=1&Ntt=throttle
Posted June 20, 2015 - 11:14 AM
Parts ordered will be back plowing again soon.
